d16a6 to d16z6 swap. ECU question
Old May 9, 2006 | 10:15 AM
s12racing's Avatar
New User
Default d16a6 to d16z6 swap. ECU question
i've got a 91 crx si and i'm about to swap the d16a6 for a d16z6 my car is manual now but the engine im swaping is auto. is there anything i need to do to the ecu? can i still use my manual trans or do i need a 92-95 manual trans? is there any special wiring that needs to be done besides v-tec?
any help would be appreciated
thanks
even though i am swaping the whole engine should i treat it just like a mini-me
Modified by s12racing at 11:32 AM 5/9/2006
Old May 9, 2006 | 11:11 AM
A1's Avatar
A1
Default Re: d16a6 to d16z6 swap. ECU question (s12racing)
used ur si trany w/92 up clutch kit and flywheel on the new z6 motor and get the non-obd to obd1 jumper harness.
Old May 9, 2006 | 11:12 AM
jlicrx's Avatar
the engine being from an auto car won't matter - just put your Si flywheel and clutch on it (use the Si flywheel bolts) - wiring depends on whether you are staying OBD0 or switching to OBD1 - use the Si engine harness and modify it as necessary - same wiring as if you were just putting the D16Z6 head on your engine
Old May 9, 2006 | 11:24 AM
R_type's Avatar
well if you got an automatic motor and everything did you get an auto ecu as well??? if you did then your gonna have to chip it
armstr9989
Mar 20, 2019 02:45 AM
Shan243
31
Oct 4, 2013 06:46 PM
wfocrx
Apr 15, 2006 10:20 PM
Amf_crx
Mar 20, 2004 02:52 PM
