installing clutch, have question on where to grease
Old May 9, 2006 | 05:24 AM
lv6l's Avatar
Default installing clutch, have question on where to grease
installing clutch in my sohc. i been reading and one site says to grease your input shaft and throw out bearing where it contacts with the arm, well i dont know exactly where that is. also, the site says to not pack the throw out bearing with grease, can someone tell me how this is done. thanks.
Old May 9, 2006 | 05:25 AM
sohcvtec1995's Avatar
Well me for one have never done this, nor do i know of anyone who has. I say just throw it all back together. i would imagine they say to do the input shaft to ease in the reassembly of the tranny to the block.
Old May 9, 2006 | 05:36 AM
lv6l's Avatar
is the input shaft the shaft with the teeth/splines on it?
Old May 9, 2006 | 05:37 AM
Default Re: (lv6l)
yea its in the tranny and thats what slides in between the clutch PP and flywheel. Its sticking out you cant miss it.
Old May 9, 2006 | 05:38 AM
alltech_hybrid's Avatar
Default Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l &raquo;</TD></TR><TR><TD CLASS="quote">is the input shaft the shaft with the teeth/splines on it?</TD></TR></TABLE>
correctomundo! but dude if this is your first clutch install i suggest you invest in a haynes manual and a friend with some experience.. dont wanna fck your sh*t up
good luck
Old May 9, 2006 | 05:57 AM
lv6l's Avatar
no its not my first, i did 2 others, just i always forget to grease. works fine the 1st two times but was just wanted to grease it this time.
also, do i grease the throw out bearing itself? inner circle? outter? how much?
Old May 9, 2006 | 06:06 AM
snatch's Avatar
Default Re: (lv6l)
You can throw a little grease on the inner race of the throwout bearing, but if you grease the input shaft then the inner race of the bearing will get some grease on it anyways.
Old May 9, 2006 | 06:22 AM
nota-eg's Avatar
Default Re: (******)
I have a Haynes manual and it didn't do dick for me when I did my clutch.
You are supposed to grease the input shaft, bearing, and the ball that connects the TOB fork to the transmission.
I didn't know you wern't supposed to pack the TOB. Oh well, my buddy packed mine and we put it in. No problems as of yet.
BigDaddyRich
Jan 2, 2012 10:41 AM
civicgsr499
Dec 11, 2008 07:06 PM
LSEGHATCH
Jun 28, 2006 12:21 PM
keithv
21
Mar 11, 2003 04:11 PM
