Questions about an EG6
Old May 9, 2006 | 04:51 AM
g2tegsownsgirl's Avatar
Default Questions about an EG6
Correct me if I am wrong, but isn't the EG6 the Civic SiR Hatchback in Japan? Now all EG6 parts are compatible with USDM Hatchs right (I understand that engine components might not since they are based off a B16A). So if I bought an Exhaust for an EG6, then that exhuast is for a 3 Door Civic Hatch with a B Series Motor Right? So if I had an EG6 exhaust w/ a B18A swap in my USDM Civic hatch then theoretically it would bolt up right? Also do they use Catalytic Converters in Japan? If not would the exhaust be designed for not cat?
*update* The exhaust I am looking at has the 3 bolt flange at the end, so it looks like it mounts up to a cat.
Thanks Guys
Old May 10, 2006 | 04:54 AM
WOW!
Nobody eh?
Old May 10, 2006 | 05:13 AM
LST4CIVIC's Avatar
you putting to much thought into this
Old May 10, 2006 | 05:21 AM
SpydiR's Avatar
Default Re: (LST4CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LST4CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">you putting to much thought into this</TD></TR></TABLE>
most people don't put enough thought into their mods
to OP: I'm fairly certain an EG6 exhaust an EG6 exhaust, the only differences in systems being whether the piping goes over or under the rear LCAs. the exhaust manifolds are different from d to b series, but I'm pretty sure the cat-back systems are the same and the length difference is made up in the cat. or test pipe. I don't have a b-series though, so I'm not sure. you could defintely search and find out though.
Old May 10, 2006 | 05:49 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Questions about an EG6 (g2tegsownsgirl)
You make way too many exhaust threads lol.
It should be fine, but just go to meineke if it doesn't. Its not like you have to go back a bunch of times or something
isaacEK
Jul 11, 2008 01:07 PM
simplemanseven
Nov 15, 2007 01:28 PM
DJNauTicz
12
Oct 7, 2007 01:11 PM
gloverboy_03
Oct 5, 2006 05:18 PM
L_K
Sep 13, 2006 08:52 PM
