exhaust help!
exhaust help!
I have a stock 95 civic. i plan to get an aftermarket exhaust system for it. My question is when i get a b series motor will it direct bolt on to the exhaust pipings or would i have to cut off some?
I think more infomation is in order...i know on my 99 coupe i did not have to change anything when i swapped to my b series...but again i think more info is needed in order to make a more educated guess
Re: (gloverboy_03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gloverboy_03 »</TD></TR><TR><TD CLASS="quote">Ohh sorry. It's an 4 dr lx. </TD></TR></TABLE>
Im going to say you should be fine. Where you may run into an issue at least where i did was a gap between the header and the cat but the exhaust was fine. I dont think there will be a problem. Since most exhausts are purchased from the cat back you wont have anything to worry about with the exception of the header bolting up to the cat after the swap.
