What cats are you guys using to pass smog in California
Old May 8, 2006 | 11:20 PM
jefe's Avatar
Default What cats are you guys using to pass smog in California
I replaced my stock cat last year with a Monza to pass smog. It worked but the cat has crapped out on me this year when trying to pass smog.
I need a new brand. What are you guys using to consistently pass smog with?
Old May 8, 2006 | 11:22 PM
SiYouLater's Avatar
Default Re: What cats are you guys using to pass smog in California (jefe)
Stock.
Old May 8, 2006 | 11:27 PM
hatchi's Avatar
oem is the way to go
Old May 8, 2006 | 11:59 PM
broketuner-Sol_Si's Avatar
Default Re: What cats are you guys using to pass smog in California (hatchi)
I barely passed using a new high flow cat by dynomax. If you use a high flow cat I would reccomend using that garanteed to pass stuff.
Old May 9, 2006 | 02:50 AM
killa rex's Avatar
STOCK STOCK STOCK..NEVER FAILS...EXCEPT WHEN IT GETS OLD AND POORLY MAINTAIN
Old May 9, 2006 | 04:54 AM
lv6l's Avatar
oem stock. never tried anything else.
Old May 9, 2006 | 07:49 AM
jefe's Avatar
Default Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l &raquo;</TD></TR><TR><TD CLASS="quote">oem stock. never tried anything else.</TD></TR></TABLE>
a landslide victory for oem. Anyone else using aftermarket?
Old May 9, 2006 | 09:02 AM
suspendedHatch's Avatar
Default Re: (jefe)
Magnaflow/Carsound high flow cat. But only because the stock cat had crapped out.
Old May 9, 2006 | 09:22 AM
dohcVTECeg2's Avatar
Default Re: (suspendedHatch)
i have a tabby
Old May 9, 2006 | 11:36 AM
jefe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">oem is the way to go</TD></TR></TABLE>
The price for a replacement cat from Honda...almost $600.
That's all good and everything and I'm sure they are handy when passing smog, but who has that kind of money for a cat??
Sounds like my best bet is Magnaflow, from some responses I have gotten and other posts I have read.
Old May 9, 2006 | 11:51 AM
philosofy1's Avatar
i don't know about cali, but i heard on the east coast these are the cats they are using.
LOL, just having fun.
Old May 9, 2006 | 11:54 AM
patdow1's Avatar
I used a Random Technology direct fit catalytic converter which I installed in 1998 and passed ever time till I stopped driving the car in 2004.
Old May 9, 2006 | 11:56 AM
Sleepy_Red_hatch's Avatar
Default Re: What cats are you guys using to pass smog in California (philosofy1)
1:keep the cat you have there
2:find 5 other honda owners in the same obd-compliance as you
3:ban together and buy the cat (600 / 6 = 100 each)
4: keep the car you have already on until its smog time, then install the oem cat
5: pass smog
6: remove and hand to another friend that needs to pass smog
7: repeat as needed, and since the cat gets used for only 6 days per year, it will stay mint for a long long time
Old May 9, 2006 | 12:04 PM
jefe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">i don't know about cali, but i heard on the east coast these are the cats they are using.
LOL, just having fun. </TD></TR></TABLE>
Are those direct bolt on??
Old May 9, 2006 | 12:07 PM
jefe's Avatar
Default Re: What cats are you guys using to pass smog in California (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch &raquo;</TD></TR><TR><TD CLASS="quote">1:keep the cat you have there
5: pass smog
7: repeat as needed, and since the cat gets used for only 6 days per year, it will stay mint for a long long time </TD></TR></TABLE>
That's a good idea, but I am a bit of a loner with all of this. Never really was in the 'scene' that much, especially now that I moved to Cali...its just sort of a hobby for me....so I seriously do not know one other person out here that works on honda's that I can hang out with...
i know, sad life...
Old May 9, 2006 | 01:25 PM
JALOP B16's Avatar
Just go find some 1 with a modified srt4, ask them for there stock cat.
Old May 9, 2006 | 03:13 PM
OxidizedSol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Magnaflow/Carsound high flow cat. But only because the stock cat had crapped out. </TD></TR></TABLE>
Same here. I got a Magnaflow because the OEM one needed to be replaced. I got mine off eBay for around $40 and just got the stock flanges welded on. Passed smog just fine, even at a Test-Only center.
Old May 9, 2006 | 03:45 PM
LuCkYcOuPe's Avatar
oem cat with a 91 dx exhaust manifold!
Old May 9, 2006 | 03:50 PM
SiRMike's Avatar
This is what I do for emission test up here in B.C., Canada.
I run a test pipe 364 days a year, and the one day that I need to go through and do my emission test, I put my oem cat back on...then once I pass and get home, off with the cat, and back on with the test pipe.
Old May 9, 2006 | 03:59 PM
1EK1EG's Avatar
Default Re: What cats are you guys using to pass smog in California (OxidizedSol)
Stocki have some straight pipe that was given to me but its always good to keep the stock one around.Try making a a WTB post and see if anyone has a good stock one for sale.I'm sure it'll be cheaper then $600.I paid $50 for mine.I would let you borrow it but your in so calGood luck man.
Old May 9, 2006 | 04:42 PM
ZCVTEC-SOHC's Avatar
From: PhantomGrayEH2, CA Where Gay Arnold Rules, USA
Default Re: What cats are you guys using to pass smog in California (GreenCivicEg)
What car/engine do you have?
I have a Magnaflow hi flow cat, never smogged it but before you buy one I've heard mix reviews on the Magnaflow cat. It's sort of a hit and miss cat, some go bad almost instantly and some last a long time. I've got lucky and I've had mine for over a year. If I was you I'll get a Magnaflow hi flow cat, if you don't pass put on two. Get it on ebay.
Old May 9, 2006 | 04:46 PM
professor poon's Avatar
OEM rsx-s cat custom fit. Got it for 65 bux and its way bigger that the oem one.
Old May 10, 2006 | 07:40 AM
TEST ONLY's Avatar
OEM is the only way to go....
Old May 10, 2006 | 09:45 AM
axtran's Avatar
i had a magna hi-flow put in using D16Y7 engine, got nearly zero on NO and CO% readings, extremely LOW HC. so, i'd say its a good cat.
this is california too, and i ran it inside of a '92 DX (stock D15 and not BARed) and it passed just fine.
Old May 10, 2006 | 11:59 AM
TEST ONLY's Avatar
Default Re: (axtran)
Sounds like you did great, and you have a really healthy engine......
