valve clicking in engine
well i got an 01 ls integra ..my engine is making some kind of knocking sound when i rev or no rev it clicks when its on idle or when i press the gas... i fix the problem once and it went away .. i got the valves retighten and its was quite for a day or two.. then i brought it to the dealer they said it was fine but my friend has the same model and mods on his car and it does not click at all.. any idea guys need help!!!
"my engine is making some kind of knocking sound when i rev or no rev it clicks when its on idle or when i press the gas."
so what your saying is that its clicking all the time, right?
run some engine cleaner through it (local parts store $5), follow the directions, change the oil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2teg »</TD></TR><TR><TD CLASS="quote">YO need a valve adjustment. My old LS did it all the time, its not bad for the engine. Its probably the valve springs.</TD></TR></TABLE>
what he said valve adjustment and oil change
this is a 2001 LS, not an old LS. My 91 ticks, so does everybodies, normal, but a 2001? I doubt his valves need adjusting. You can always check the valve lash.............$4 tool, remove valve cover, follow instructions in manual or found online, prob take you 60mins first time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cm zak »</TD></TR><TR><TD CLASS="quote">year doesnt really matter, more so how you drive the car, it could be valves need adjustment.</TD></TR></TABLE>
did you read original post.
'loud injectors'
wow... you're a winner. honda's are however notorious for valve click. they need to be adjusted with every oil change or there about if you have a vtec motor. trust me... a bit of click is alright, but you need to make sure the clearance is up to par etc.
have someone adjust the valves and make sure the valves are clearanced properly.
Dont do the parts cleaner. BAD IDEA NUMBER ONE. I got my head ported and polished. Weak later tried some motor flush. Then changed my oil to go to races. BAD IDEA. Ruined the valve seals
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black Widow g2 »</TD></TR><TR><TD CLASS="quote">'loud injectors'
have someone adjust the valves and make sure the valves are clearanced properly.</TD></TR></TABLE>
valves adjusted every oil change?..... i dont think the valves go out of spec that quickly
If you put motor flush in your engine and it ruined your valve seals you did something wrong. Sheesh, its $4 at the parts store, it can't be that strong. What did you do, leave it in your car? Its called "Flush" for a reason, your supposed to run it and change your oil right then, not a week later. Regardless of what you did or didn't do, MOTOR FLUSH could not, and did not, ruin your seals. Perhaps it was the racing???
Brembomaster
May 26, 2019 07:51 PM
Comptech98GSR
Aug 27, 2002 08:55 PM
