manual conversion on a honda accord 92 lx
Old May 8, 2006 | 05:56 PM
EvilT's Avatar
Default manual conversion on a honda accord 92 lx
Hi, im wanting to convert my automatic accord to an manual, my ? is what are the parts i will need to do this and what kind of price am i lookin at.
thx
Old May 8, 2006 | 06:22 PM
steve96accord's Avatar
Default Re: manual conversion on a honda accord 92 lx (EvilT)
TOO Much work lol just keep the auto.. but u need 5 speed tran duh.. clutch cables/pedle shifter place 4 ur shifter... thats all i know off to much Stuff i think
Old May 8, 2006 | 06:27 PM
NAiL05's Avatar
The money you spend on it your better off buying another 5speed accord. Unless your really dedicated you need the...
Clutch MC, Pedal Assembly from a manual Accord, shift linkages/shifter, Manual Trans, I think the axles are diff, clutch, flywheel and some other stuff i cant think of right now.
Old May 8, 2006 | 06:51 PM
EvilT's Avatar
i can get all the parts from the guy at the junk yard for basical free so i was just wonderin wha i needed
Old May 8, 2006 | 08:16 PM
93acclude's Avatar
trans, axles, ecu, shifter, shift cables, shift boot and ****, clutch pedal assembly, brake pedal assembly, clutch master cylinder, slave cylinder, clutch reservior, clutch lines,clutch and flywheel, new trans mount. I think there is some cutting and welding involved for the trans mount placement.
Thats a complete list. If you are getting parts from the junkyard, you should be able to get everything for under a grand. Get new clutch lines though. Labor's gonna cost you, depending on where you go, probably around another grand or so.
On a newer car I would say go for it, but on a 92 it might not be worth the time, money and effort.
Old May 8, 2006 | 11:53 PM
BlUAc's Avatar
Default Re: manual conversion on a honda accord 92 lx (93acclude)
93acclude got it right but you only need the driver side axel and half shaft also the starter is different so pic it up to
Old May 9, 2006 | 05:26 AM
EvilT's Avatar
Were can i get a good clutch, and a light weight flywheel
Old May 9, 2006 | 07:31 AM
NAiL05's Avatar
XTD is decent from what ive heard i have a stage 3 i still need to install in my car. But i see quite a bit of people run a fidanza flywheel with the exedy stage 1 clutch.
Old May 9, 2006 | 09:06 AM
EvilT's Avatar
Default Re: (NAiL05)
im thinkin bout goinin and getin a prelude motor etheir an H23A1, B20A5 or F22A1, would i have to get the prelude trans to go along with it or can i use the one thats in my car?
Old May 9, 2006 | 09:34 AM
TouringAccord's Avatar
H-T Order of Merit
Auto to Manual Transmission swap reference (on CB7Tuner)
Automatic to Manual Transmission Conversion (on AccordinglyDone)
Old May 10, 2006 | 07:56 AM
BlUAc's Avatar
Default Re: manual conversion on a honda accord 92 lx (TouringAccord)
those are some good detailed ryt ups drill that in your head
MestizoRacer310
May 1, 2020 05:12 PM
Sean Cirillo
Mar 24, 2016 04:52 PM
mugenmarauder
Jul 25, 2014 11:38 AM
hondafreak2134
Jan 1, 2010 06:40 PM
MilkyLep
May 26, 2007 10:42 PM
