Does the tranny oil have to be drained to replace the clutch.
Old May 8, 2006 | 05:10 PM
streetracerof06's Avatar
Default Does the tranny oil have to be drained to replace the clutch.
I am doing a swap and I was planning on taking the tranny off and replacing the clutch while its out of the car. I was just wondering if this can be done with out draining the tranny oil. I would think it does not have to be drained because the clutch is not in oil, but I was just wanting to make sure.
Old May 8, 2006 | 05:16 PM
DestructoEH's Avatar
Default Re: Does the tranny oil have to be drained to replace the clutch. (streetracerof06)
If you're removing the tranny, more than likely you'll end up removing the axles. You should probably drain it beforehand.
Old May 8, 2006 | 05:18 PM
d16civic111's Avatar
yes the oil does have to be drained out(found out the hard way) when you pull out the axles it will all come out and go everywhere.theres a 1/2 inch drive opening for a 1/2 drive racthit, i think its on the pass. side. the oil is in there for the gears
Bserieskiller's Avatar
yes. the trans oil must be drained or you're going to get that **** all over you when you pull out your axles. i changed my clutch and flywheel too. let me know how it goes.
Old May 8, 2006 | 05:19 PM
LowSlow93Sol's Avatar
Not unless you can leave the cv axels in the trans when you pull it.
Old May 8, 2006 | 05:22 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Does the tranny oil have to be drained to replace the clutch. (d16civic111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16civic111 &raquo;</TD></TR><TR><TD CLASS="quote">yes the oil does have to be drained out(found out the hard way) when you pull out the axles it will all come out and go everywhere.theres a 1/2 inch drive opening for a 1/2 drive racthit, i think its on the pass. side. the oil is in there for the gears</TD></TR></TABLE>
It's actually a 3/8ths drive ratchet plug for the drain and a 17mm for the check/fill that sits up higher.
When you refill it, unscrew the 17mm check/fill and the VSS sensor on top of the transmission. Pour the fluid into the VSS hole and stop when it comes out the check/fill galley. It should be no more than 2 quarts.
Old May 8, 2006 | 05:47 PM
Syndacate's Avatar
lol, no, do what I did, pull the axles and say OH **** as u watch it spew out all over the place
Yes, drain the oil from the pan first O.O
Old May 8, 2006 | 05:52 PM
nota-eg's Avatar
Default Re: Does the tranny oil have to be drained to replace the clutch. (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">It's actually a 3/8ths drive ratchet plug for the drain and a 17mm for the check/fill that sits up higher.
When you refill it, unscrew the 17mm check/fill and the VSS sensor on top of the transmission. Pour the fluid into the VSS hole and stop when it comes out the check/fill galley. It should be no more than 2 quarts.</TD></TR></TABLE>
Only thing I would change with this is I'd fill it through the vent on the front of the transmission instead of through the VSS. It should have a little black rubber piece on it. It's much easier to fill it through there than through the VSS, at least for me it was.
Old May 9, 2006 | 04:56 PM
Default Re: Does the tranny oil have to be drained to replace the clutch. (nota-eg)
I have already pulled the axles and the engine, I only lost a little bit of tranny oil, but will it be ok to pull the tranny with the oil thats in it.
Old May 9, 2006 | 05:52 PM
E46Kid's Avatar
It would be a good idea to do it
projsectEF
Oct 18, 2006 08:29 PM
lowgman
Apr 2, 2005 02:00 AM
Adriano
Jun 8, 2003 04:57 PM
TurBoXBirD16
Jun 30, 2002 11:32 AM
hybridcrx
Mar 13, 2002 08:41 AM
