d series tranny
d series tranny
alright I might not know much about anything but ain't it suppose to leak tranny oil when I take out my axles? well I took out my axles like i said and it didn't leak any tranny oil. Now is that A good thing or bad thing
It's okay providing you have oil in there. If some comes out axle seals when the axles are out when car is jacked up unlevel then it's okay (even if level and some comes out then you had a little extra in there) Make sure to check the fluid level. With car on level ground remove the 17mm Fill plug just behind the passenger side axle. You should stick your pinky finger down into the hole and feel the oil level. If you don't feel the oil level you MUST add some.
Re: (BlueCrxNC)
well thanks guys. I guess I'll have to add some oil. I think thats why my gears don't feel smooth and when I press on the clutch and try to shift its kinda difficult.
especially when shifting to reverse.
Kid-jdm-teggy
Transmission & Drivetrain
09-10-2013 08:41 PM
