Difference between b16-a3 and b16-a2?
Old May 8, 2006 | 02:17 PM
auburnBoy's Avatar
Default Difference between b16-a3 and b16-a2?
yes i know which cars they come out of...but what about differences if any.
Old May 8, 2006 | 02:27 PM
bmoua's Avatar
i think the a3 is off the del sol and the b16a2 is off a Si...also the A2 has a little more torque
Old May 8, 2006 | 03:23 PM
auburnBoy's Avatar
Default Re: (bmoua)
from what ive read all the specs are the same...and like i said, i know which cars they come from. i wanted to know if there was any other differences like redline or if one can take more abuse than the other or where to purchase a b16a3 cause i cant seem to find one anywhere.
Old May 8, 2006 | 04:21 PM
Jedi_Sol's Avatar
Default Re: (auburnBoy)
The difference is the a3 is obd1 and the a2 is obd2. That just means the a2 has more sensors on the motor.
Essentially they are the same exact motor.
Old May 8, 2006 | 09:43 PM
auburnBoy's Avatar
Default Re: (Jedi_Sol)
so would it be harder to put a2 into a non vtech del sol than a3 since the a3 is already obd1?
Old May 8, 2006 | 09:49 PM
axtran's Avatar
yes auburnBoy nice job on your reading comprehension skills. you can always take an a2 and tack on all obd1 stuff too, but its more work.
Old May 8, 2006 | 10:21 PM
auburnBoy's Avatar
Default Re: (axtran)
so was the a3 only usdm? is that why i cant find on any jdm motor site?
Old May 8, 2006 | 10:29 PM
97_delsol_Vtec's Avatar
jdm is only B16a no a2 no a3....i believe the b16a3 redline @ 8200 rpm on del sols...and a2 is @ 8000 but it could just be the ecu ??? and yes its USDM on 94 model del sol's
Old May 8, 2006 | 11:11 PM
auburnBoy's Avatar
Default Re: (97_delsol_Vtec)
from what i read on spec web sites its 94-95 models
Old May 8, 2006 | 11:15 PM
auburnBoy's Avatar
and yes your right about the no 1,2,or3 on the block. but the jdm b16's are sir, sirII,xsi,and B for type R right. and the sirII is the same as b16a2 right? and the xsi is from an integra...so wheres A3?
Old May 9, 2006 | 12:04 AM
broketuner-Sol_Si's Avatar
The A3 is most similar to the 2nd gen b16a that is OBD 1 and has the hydro tranny. All are very close. The only thing that differentiates them is the OBD level and a cable or hyrdo tranny.
For example:
USDM Motors- have slightly lower compression and usually a little less hp/tq than jdm/edm motors due to emissions standards
A2: OBD 2B(OBDII A is 96-98 in the 96-97 sols) w/hydro
A3: OBD1 w/ hydro
JDM/EDM motors
1st gen B16a: OBD 0 w/ cable tranny
2nd gen B16a: OBD1 w/ hydro tranny(similar to b16a3)
XSi b16: OBD 1 w/ cable tranny(at least according to most swap sites...some don't even list this motor)
Old May 9, 2006 | 04:26 AM
kleanlscivic's Avatar
Default Re: Difference between b16-a3 and b16-a2? (auburnBoy)
i am dealing with this also, all the torque specs the same?
Old May 9, 2006 | 04:49 AM
t0p_sh0tta's Avatar
Default Re: Difference between b16-a3 and b16-a2? (kleanlscivic)
All are close (within ~1 ft/lb)
Old May 9, 2006 | 08:48 PM
auburnBoy's Avatar
Default Re: (broketuner-egb16a)
gotcha, thanks
Old May 9, 2006 | 08:56 PM
auburnBoy's Avatar
jdm motors have more hp/trq than their usdm version, as we all know...but does the jdm del sol b16 have more hp/trq than its usdm version?
Old May 9, 2006 | 09:05 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by auburnBoy &raquo;</TD></TR><TR><TD CLASS="quote">jdm motors have more hp/trq than their usdm version, as we all know...but does the jdm del sol b16 have more hp/trq than its usdm version? </TD></TR></TABLE>
Yes. The JDM 2nd-generation B16A has 168hp @ 7800 RPM. The USDM B16A3/B16A2 has 160hp @ 7600 RPM.
Old May 9, 2006 | 09:18 PM
nekoabandoned's Avatar
Default Re: (Targa250R)
30005 - B16A 92-95 (SiR-II)
170Hp 113Trq 10.4 Compression (JDM)
160Hp 111Trq 10.2 Compression (USDM) &lt;---------
Old May 9, 2006 | 09:28 PM
Targa250R's Avatar
be professional
Default Re: (nekoabandoned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekoabandoned &raquo;</TD></TR><TR><TD CLASS="quote">30005 - B16A 92-95 (SiR-II)
160Hp 111Trq 10.2 Compression (USDM) &lt;---------</TD></TR></TABLE>
The 170 number is PS, not HP.
Old May 9, 2006 | 10:08 PM
GG99's Avatar
1 ps = 0.98632 hp
Old May 10, 2006 | 01:10 AM
siregcivic's Avatar
Default Re: (GG99)
here a little searching and heres what i got out of it. pretty interesting.. tells the car and motor and all the hp and tq specs..
http://en.wikipedia.org/wiki/Honda_B_engine#B16A
Erik_Pb_Foot
22
Feb 6, 2015 11:50 PM
scott_turner
20
Apr 25, 2011 07:46 AM
-JSpecEk*9-
11
Jul 23, 2005 10:56 AM
civic2slo
Jan 5, 2005 06:12 AM
compwc18
Jun 17, 2004 02:59 PM
