Suspension & Brakes Theory, alignment, spring rates....
Need lowering adjustable coilover help!!!
Old May 8, 2006 | 01:42 PM
integracura's Avatar
Default Need lowering adjustable coilover help!!!
I have matrix adjustable coilovers. I dont really know how to adjust them, my back ones are lower than the front need help. I got the tool thing. Just want to know how to lower it.
Old May 8, 2006 | 02:12 PM
anyone?
Old May 8, 2006 | 02:18 PM
A.E Motoring's Avatar
Default Re: (integracura)
turn the perch counter clock wise
Old May 8, 2006 | 03:32 PM
so do i lower the bottom one first then the top one?
Old May 8, 2006 | 04:32 PM
do the bottom one first to where u want it, then the top one
Old May 8, 2006 | 05:11 PM
PIC Performance's Avatar
Default Re: Need lowering adjustable coilover help!!! (integracura)
Turn the spring perch and perch lock against each other as tight as you can get them, so that when you turn one, the other turns along with it, and turning them will turn the entire shock body as well.
Then loosen the lowest collar (the lower mount collar) so that you have room to adjust. To lower the car, turn the spring perch/perch lock clockwise (when viewing from the top). To raise the car, turn counter clockwise.
Remember to tighten the lower mount collar after adjusting your heights.
Old May 8, 2006 | 07:01 PM
man this seems to complicated, i just dont want to screw up anything, does anyone know where i could see a video or steps of images?
Old May 8, 2006 | 07:11 PM
Complicated? Not really.
What is your email addy? I will send you an electronic copy of our installation manual (it has pictures).
Old May 14, 2006 | 01:39 PM
Zeductive's Avatar
Default Re: (PIC Performance)
zeductive@gmail.com instructions needed
Old May 14, 2006 | 02:40 PM
atownakaatl@yahoo.com, meet to i need instructions.
jdm2envy
Suspension & Brakes
Jul 4, 2008 01:03 AM
Razr2
May 16, 2008 09:27 PM
kaluwa3
Suspension & Brakes
May 13, 2007 03:39 PM
jakeiscool
Suspension & Brakes
Mar 20, 2007 04:50 PM
needashell1234now
Suspension & Brakes
Jan 27, 2007 11:35 AM
