msd coil problem........... anyone?
Old Apr 10, 2002 | 12:39 PM
uneekcrx's Avatar
Default can someone help with msd coil problem.......
i just installed my msd 6a ignition w/blaster 3 coil and boost timing master.....everything starts but the coil seems to be arcing.......from the + and -- of the coil to the top of the coil where the wire goes..i don't understand can someone give me any ideas what to do to fix this.....and everything is connected correctly and tightly
[Modified by uneekcrx, 12:07 AM 4/11/2002]
Old Apr 10, 2002 | 03:07 PM
uneekcrx's Avatar
Default Re: can someone help with msd coil problem....... (uneekcrx)
ttt
Old Apr 10, 2002 | 03:16 PM
Pritos's Avatar
New User
you have to put your index finger from your left hand to the + and the index finger from your right to the - and have someone start the car. That way you can push the sparks back in.
seriously though. With the plug wire ON from the coil to the distributor it does this? Or without the wire connected? maybe a defective wire. I never knew the spark could jump that far. damn.
Old Apr 10, 2002 | 04:38 PM
uneekcrx's Avatar
Default Re: can someone help with msd coil problem....... (Pritos)
it's not arcing from the dist. it's arcing from the pos. & neg. of the coil to where the wire connects to the top of the msd coil..sorry
i have no clue what to check
Old Apr 10, 2002 | 05:41 PM
speedworks's Avatar
is the coil new or used
Old Apr 10, 2002 | 06:08 PM
uneekcrx's Avatar
Default Re: can someone help with msd coil problem....... (speedworks)
used
Old Apr 10, 2002 | 07:15 PM
Smashback's Avatar
Unfortunately it sounds like you bough somebody else's problems.
Old Apr 10, 2002 | 07:27 PM
uneekcrx's Avatar
Default Re: can someone help with msd coil problem....... (94hondahybrid)
do you think that putting something on the terminals would help??????
Old Apr 10, 2002 | 07:29 PM
paulzy's Avatar
it's only another 30 bucks for new one....just go get it and be happy again
Old Apr 10, 2002 | 07:31 PM
uneekcrx's Avatar
Default Re: can someone help with msd coil problem....... (Slow_ass_4dr)
what i bought came with a blaster 3 coil what's the difference in the blaster 2 and 3 coils does the blaster 3 have more or less spark.....?
Old Apr 10, 2002 | 08:19 PM
paulzy's Avatar
to my knowledge, it's just a blaster2 with a different body casing to try and up sales
[Modified by Slow_ass_4dr, 9:20 PM 4/10/2002]
Old Apr 10, 2002 | 08:23 PM
SiR Kid's Avatar
New User
Uh, have you replaced the coil wire yet? Arcs happen from the closed power to the closest ground int he system... if the wire's not hooked up inside the coil right, or the wire has a gap inside it, this might happen...
First test.. replace the coil wire.
The coil is probably fine, because the car runs, right? It's putting out power then. but the wire isn't transferring the power correctly.
Old Apr 10, 2002 | 08:30 PM
2000_Civic_Si's Avatar
Default Re: can someone help with msd coil problem....... (SiR Kid)
I got the blaster 2, and it doesn't do this. Also when i installed this it was a bitch to figure otu how the wire attached to the coil. I had to buy some little screw tyoe thign to go ont the top and sometimes i think it isn't hooked up correctly, cause it is not really secured with anything.
I think you got a shitty coil. Cal MSD and see what they have to say.
Old Apr 11, 2002 | 04:58 AM
uneekcrx's Avatar
Default Re: can someone help with msd coil problem....... (2000_Civic_Si)
cool thnx.........
Old Apr 11, 2002 | 05:18 AM
PM-Performance's Avatar
yea did you do all that **** with taking out the stock coil to wire this one up?
that sounds kinda strange , sounds like it was installed wrong to me .
Old Apr 11, 2002 | 07:38 AM
uneekcrx's Avatar
Default Re: can someone help with msd coil problem....... (itr206)
sure did.....i hooked it up according to the directions.......removed the old coil and stuff
Old Apr 11, 2002 | 07:56 AM
maybe the coils shot then
Old Apr 11, 2002 | 09:05 PM
SiR Kid's Avatar
New User
The path of least resistance SHOULD be the coil wire running from the coil terminal to the distributor, which are all hard connections except a SMALL 1/16" gap for the rotor/cap...
If it's arc'ing the 1/2 inch or whatever to the wire from the power terminal, you've got a wiring issue somewhere. Check continuity on your coil wire from the coil to the distributor!
si_motor_spt
Oct 29, 2020 09:54 AM
Metal Head
Feb 8, 2009 05:32 PM
r1ch1e
Aug 30, 2007 11:12 AM
WeaponR
Apr 4, 2004 09:44 PM
