do all weld pak 100's upgrade to mig?
Old May 8, 2006 | 08:39 AM
93preludes's Avatar
Default do all weld pak 100's upgrade to mig?
I found one of these for really cheap so i went ahead and bought it. I have a question though, there is no port for gas on the back... does this mean that I have the model which can not be upgraded? If its available I will be buying the mig kit but i want to be sure before i buy it.
thanks in advance
edit: oops, think i answered my own question
Old May 8, 2006 | 09:14 AM
RCautoworks's Avatar
Default Re: do all weld pak 100's upgrade to mig? (93preludes)
IM sent
Old May 8, 2006 | 09:35 AM
93preludes's Avatar
Default Re: do all weld pak 100's upgrade to mig? (90blackcrx)
thanks alot for taking the time to answer my questions, i really appreciate your help with everything.
Old May 8, 2006 | 02:02 PM
HighRevn's Avatar
I have the same question, what did you find out, I had the HD though
Old May 8, 2006 | 03:56 PM
Default Re: do all weld pak 100's upgrade to mig? (HighRevn)
Pretty sure all are able
Old May 9, 2006 | 12:56 AM
Lamchop0000's Avatar
i upgraded my weldpak 100 to mig. a long time ago. but it comes with a gas solenoid.
which has a gas inlet on it.
which you mount inside the machine and it sticks out of a hole thats already there.
i forget if the hole had plug or not. that you pop off.
Old May 9, 2006 | 06:04 AM
93preludes's Avatar
Default Re: do all weld pak 100's upgrade to mig? (Lam.N)
you got it lam.n, looks that way on mine and i have a non "hd" weld pak. thanks for the help!
jdmISmyGOD
Welding / Fabrication
Mar 18, 2011 10:43 AM
twkdCD595
10
Dec 19, 2010 07:48 AM
juiced2ndgenteg
Jan 31, 2010 04:20 AM
elpiar
Feb 14, 2006 03:28 PM
94civicx
Jan 3, 2003 08:36 AM
