Hose from valve cover to intake pipe?
Old May 8, 2006 | 06:24 AM
DannyDeuce's Avatar
Default Hose from valve cover to intake pipe?
Can you have the hose (the one from the valve cover to the intake pipe) connected if your vehicle is turbo charged? If not, why?
Please advise, thanks.
DAN
Old May 8, 2006 | 06:41 AM
Boilermaker1's Avatar
put a catch can inbetween.
Search for the enormous Catch can/ Crankcase evac thread, its all outlined.
Old May 8, 2006 | 06:58 AM
DannyDeuce's Avatar
Default Re: (Boilermaker1)
^^ Yeah thanks.....I've read the threads on catch can installations.
I just want to know though if their are any negative effects by hooking up the hose from the valve cover to the intake pipe if your car is turbocharged? Just as you would on a N/A vehicle.
DAN
Old May 8, 2006 | 08:09 AM
jolt-tsp's Avatar
Default Re: (DannyDeuce)
Be sure to keep it on the intake pipe after installing the turbo and not the charge pipe
Old May 8, 2006 | 08:16 AM
SavEM1's Avatar
Why would you want to keep squirting oil back in to your pipes and manifold? Then ask your self if you want to keep it.
Old May 8, 2006 | 08:19 AM
DannyDeuce's Avatar
Default Re: (Hcivic02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hcivic02 &raquo;</TD></TR><TR><TD CLASS="quote">Why would you want to keep squirting oil back in to your pipes and manifold? Then ask your self if you want to keep it.</TD></TR></TABLE>
Bingo! There's the answer I wanted. So oil will be squirting back into your pipes and mani?
I'll leave the breather on their then.........thats until i get a catchcan setup.
Thanks guys.
DAN
Old May 8, 2006 | 11:43 AM
nickromeo's Avatar
Default Re: Hose from valve cover to intake pipe? (DannyDeuce)
whatever u do just make sure you arent pumping pressurized air into your crankcase.
pre turbo vacucm.
Old May 8, 2006 | 01:52 PM
A.E Motoring's Avatar
Default Re: Hose from valve cover to intake pipe? (nickromeo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickromeo &raquo;</TD></TR><TR><TD CLASS="quote">whatever u do just make sure you arent pumping pressurized air into your crankcase.
pre turbo vacucm.</TD></TR></TABLE>
exactly, u dont want to add MORE pressure to the crank case
wtsapexipowerfc
Dec 13, 2010 09:04 AM
( o )( o )
Sep 5, 2005 10:52 PM
piotrush
Nov 19, 2004 10:51 AM
Madspeed
Jun 29, 2004 08:54 PM
BLITZ
Dec 19, 2002 03:18 PM
