Will a teg rear sway bar fit on a 98 dx ek h/b
Old May 8, 2006 | 06:05 AM
Malakai's Avatar
Default Will a teg rear sway bar fit on a 98 dx ek h/b
So like it says, will it work as long as I have teg lca's.
Old May 8, 2006 | 06:22 AM
pdiggitydogg's Avatar
you dont need teg lca's because your dx arms should have holes in them for a sway bar anyway - but if for some strange reason they dont, you would want 96-00 ex or si arms (because they would fit - teg arms will not)
other than that, yes, using 99-00 si endlinks
If youre planning to use anything above the 14mm bar, you will need a subframe brace (ASR)
Old May 8, 2006 | 07:14 AM
JdmLub's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">you dont need teg lca's because your dx arms should have holes in them for a sway bar anyway - but if for some strange reason they dont, you would want 96-00 ex or si arms (because they would fit - teg arms will not)
If youre planning to use anything above the 14mm bar, you will need a subframe brace (ASR)</TD></TR></TABLE>
what he said
Old May 8, 2006 | 08:46 AM
Malakai's Avatar
Cool thanks !!
Old Jul 29, 2006 | 07:17 PM
Charlie Moua's Avatar
Default Re: (Malakai)
<FONT COLOR="green">
I just had a few questions:
1) ek ex sedans already have same endlinks as E SI right?
2) what size is jdm itr rear sway bar & size of usdm itr bar?
</FONT>
Old Jul 29, 2006 | 07:22 PM
BlueIntegraBoy's Avatar
Default Re: (Charlie Moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote"><FONT COLOR="green">
</FONT></TD></TR></TABLE>
1. EX sedans did not get a rear sway bar
2. JDM = 23 mm (98 spec), JDM = 22 mm (96 spec), USDM = 22 mm
Old Jul 29, 2006 | 07:53 PM
Default Re: (BlueIntegraBoy)
thanks..
After searching... i'm still not 100% sure.
but IS this correct?
I will need
breaks kit
99si/gsr/itr endlinks
keep stock lca
Old Jul 29, 2006 | 07:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">thanks..
I will need
breaks kit
keep stock lca
EK?
If you use an ITR rear sway, it is HIGHLY recommended you purchase an ASR kit, not the Beaks. You then need Si endlinks, and yes you can keep your stock LCAs.
daveb91
10
Nov 26, 2005 09:58 PM
importboi22
12
Mar 8, 2004 04:14 AM
WalkEX99
Feb 3, 2003 11:57 AM
misledyouth
Dec 18, 2002 08:07 AM
02WRX
Apr 15, 2002 02:30 PM
