Will a teg rear sway bar fit on a 98 dx ek h/b
you dont need teg lca's because your dx arms should have holes in them for a sway bar anyway - but if for some strange reason they dont, you would want 96-00 ex or si arms (because they would fit - teg arms will not)
other than that, yes, using 99-00 si endlinks
If youre planning to use anything above the 14mm bar, you will need a subframe brace (ASR)
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">you dont need teg lca's because your dx arms should have holes in them for a sway bar anyway - but if for some strange reason they dont, you would want 96-00 ex or si arms (because they would fit - teg arms will not)
If youre planning to use anything above the 14mm bar, you will need a subframe brace (ASR)</TD></TR></TABLE>
what he said
Re: (Malakai)
<FONT COLOR="green">
I just had a few questions:
1) ek ex sedans already have same endlinks as E SI right?
2) what size is jdm itr rear sway bar & size of usdm itr bar?
</FONT>
</FONT>
Re: (Charlie Moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua »</TD></TR><TR><TD CLASS="quote"><FONT COLOR="green">
</FONT></TD></TR></TABLE>
1. EX sedans did not get a rear sway bar
2. JDM = 23 mm (98 spec), JDM = 22 mm (96 spec), USDM = 22 mm
Re: (Charlie Moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua »</TD></TR><TR><TD CLASS="quote">thanks..
After searching... i'm still not 100% sure.
but IS this correct?
I will need
breaks kit
99si/gsr/itr endlinks
keep stock lca
EK?
If you use an ITR rear sway, it is HIGHLY recommended you purchase an ASR kit, not the Beaks. You then need Si endlinks, and yes you can keep your stock LCAs.
I will need
breaks kit
keep stock lca
EK?
importboi22
12
03-08-2004 04:14 AM
