how do i adjust apexi twin chamber bov?
Old May 8, 2006 | 03:46 AM
RACEPAK's Avatar
Default how do i adjust apexi twin chamber bov?
hello everybody.
i got a apexi twin chamber bov on my car. and i think it needs adjustment. i think its leaking boost.
i'v searched. and tryed to adjust it.
one guy said:
"To adjust the greddy right,you got to idlethe car,like around 1000rpms(might have to idle it little higher to feel anything) turn the adjustment nut towards soft until you can feel air rushing out of it,then slowly turn it towards hard until air stops coming out,then give it like a 1/2-1 turn extra and your done."
but i dont feel any air coming out of it when the spring is loose....
Old May 8, 2006 | 08:50 AM
RACEPAK's Avatar
Default Re: how do i adjust apexi twin chamber bov? (RACEPAK)
Old May 8, 2006 | 11:19 AM
RACEPAK's Avatar
anyone?
Old May 8, 2006 | 03:05 PM
RACEPAK's Avatar
Old May 8, 2006 | 09:12 PM
RACEPAK's Avatar
Old May 8, 2006 | 09:16 PM
O16581724 5 2 5's Avatar
Though i know nothing about the Apexi, you're not leaking boost if you're not feeling anything out of it at idle. Every aftermarket valve i know of closes with a spring, plus uses boost pressure ontop of the spring, if you're not leaking air at idle, the only thing to be concerned of is a fluttering sound which is compressor surge. I adjusted my Greddy until i heard no fluttering when letting off the throttle.
Maybe it has some type of check valve system in it so it doesn't leak at idle so MAF cars can run it without running bad?
not133t
Apr 7, 2003 07:27 PM
Jdm_Rice_Monster
Jan 13, 2003 06:01 PM
Trac226
May 21, 2002 09:08 PM
BlueShadow
Apr 13, 2002 10:48 PM
98civicEX
Mar 7, 2002 08:43 PM
