Check engine light code P0135
Old May 7, 2006 | 08:13 PM
bma1818's Avatar
Default Check engine light code P0135
On my 97' civic ex I recently got this code right after I installed a hi flow cat. I bought a brand new 02 sensor for the front bank and removed the code, and it instantly came back on. What can I do to remove the check engine light? Any suggestions would help
Old May 7, 2006 | 08:21 PM
Dodger2940's Avatar
Default Re: Check engine light code P0135 (bma1818)
did you buy a new o2 sensor that goes on the header??
Old May 7, 2006 | 08:23 PM
bma1818's Avatar
Default Re: Check engine light code P0135 (Dodger2940)
Yeah I bought a brand new bosch 02 sensor for the header. Any ideas?
Old May 7, 2006 | 08:38 PM
Dodger2940's Avatar
did you reset the ECU, IE. take the + connector of the battery? then after some time put it back on?
Old May 7, 2006 | 08:54 PM
bma1818's Avatar
yeah I did all of that, and it went away for a couple of minutes and then came right back on. What should I do?
Old May 7, 2006 | 09:08 PM
Dodger2940's Avatar
Did you get an OEm replacement or did you have to splice the wires?
Old May 7, 2006 | 09:20 PM
bma1818's Avatar
I got a oem replacement
Old May 7, 2006 | 09:25 PM
Dodger2940's Avatar
Either its not pluged in right or you should take it back and get a new one. Sorry I cant help more.
Old May 7, 2006 | 09:26 PM
jdmEK209's Avatar
take the ground of the battery for 30-45 min if that dont work then turn your ignition on and of the times in like ten sec that should do it and if not then make sure that you didnt get a bad o2 or connector
Old May 7, 2006 | 09:27 PM
jdmEK209's Avatar
Default Re: Check engine light code P0135 (jdmEK209)
my bad ingnition on and off three times in like 10 sec lol
Old May 7, 2006 | 09:29 PM
bma1818's Avatar
thankx I will go try that
SuperSlow's Avatar
if it is not a true high flow cat, and just a resonator with a bung, then you will keep throwing codes.
Old May 7, 2006 | 09:36 PM
jdmEK209's Avatar
thats true too,make sure its not just regular *** piping that says its hi flow you know
Old May 7, 2006 | 09:42 PM
bma1818's Avatar
I tried turning the ignition on and off like u said that didn't work so now I just took the ground cable off
Old May 7, 2006 | 09:45 PM
bma1818's Avatar
Default Re: Check engine light code P0135 (SuperSlow)
how can I tell if it is a real hi flow cat? I bought this cat off ebay real cheap but it was brand new. If it keeps throwing the same code at me what can I do to get rid of it? Could I use a mil eliminator or a cel simulator?
Old May 7, 2006 | 09:50 PM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bma1818 &raquo;</TD></TR><TR><TD CLASS="quote">how can I tell if it is a real hi flow cat? I bought this cat off ebay real cheap but it was brand new. If it keeps throwing the same code at me what can I do to get rid of it? Could I use a mil eliminator or a cel simulator?</TD></TR></TABLE>
Did it have the honeycomb across the middle or could you see right through it?
If it is just a pipe or resonator, get the eliminator.
honda_civic1's Avatar
have you tried taking the back up fuse thats under you hood in the fuse box its a 7.5 remove that for ten seconds or so and then put it back and see if the code is still there.
Old May 7, 2006 | 09:53 PM
jdmEK209's Avatar
whats that goin to do
Old May 7, 2006 | 09:56 PM
^^ what do you mean whats it going to do?
it suppose to clear the code.
Old May 7, 2006 | 10:04 PM
bma1818's Avatar
Default Re: (honda_civic1)
I could see right thru it. What does that mean, what do I have?
Old May 7, 2006 | 10:06 PM
bma1818's Avatar
Default Re: (jdmEK209)
Yeah I tried removing that fuse under the hood but it just came right back on. I just want that check engine light off!
Old May 7, 2006 | 10:30 PM
SuperSlow's Avatar
Default Re: (bma1818)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bma1818 &raquo;</TD></TR><TR><TD CLASS="quote">I could see right thru it. What does that mean, what do I have?</TD></TR></TABLE>you need the eliminator. You don't have a high flow cat.
kaivorth
Honda Civic (2001 - 2005)
Jun 5, 2013 05:37 PM
91(si)hatchey
Mar 12, 2007 11:03 AM
Matt00
Oct 10, 2005 10:41 AM
honda_crazy88
Sep 10, 2005 11:28 AM
urbantrain
Apr 19, 2002 07:32 PM
