Check engine light code P0135
On my 97' civic ex I recently got this code right after I installed a hi flow cat. I bought a brand new 02 sensor for the front bank and removed the code, and it instantly came back on. What can I do to remove the check engine light? Any suggestions would help
Re: Check engine light code P0135 (Dodger2940)
yeah I did all of that, and it went away for a couple of minutes and then came right back on. What should I do?
Re: Check engine light code P0135 (bma1818)
take the ground of the battery for 30-45 min if that dont work then turn your ignition on and of the times in like ten sec that should do it and if not then make sure that you didnt get a bad o2 or connector
Re: Check engine light code P0135 (jdmEK209)
I tried turning the ignition on and off like u said that didn't work so now I just took the ground cable off
Re: Check engine light code P0135 (SuperSlow)
how can I tell if it is a real hi flow cat? I bought this cat off ebay real cheap but it was brand new. If it keeps throwing the same code at me what can I do to get rid of it? Could I use a mil eliminator or a cel simulator?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bma1818 »</TD></TR><TR><TD CLASS="quote">how can I tell if it is a real hi flow cat? I bought this cat off ebay real cheap but it was brand new. If it keeps throwing the same code at me what can I do to get rid of it? Could I use a mil eliminator or a cel simulator?</TD></TR></TABLE>
Did it have the honeycomb across the middle or could you see right through it?
If it is just a pipe or resonator, get the eliminator.
Re: (bma1818)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bma1818 »</TD></TR><TR><TD CLASS="quote">I could see right thru it. What does that mean, what do I have?</TD></TR></TABLE>you need the eliminator. You don't have a high flow cat.
Matt00
10-10-2005 10:41 AM
