Just bought a d16y8 swap, will my harness work?
Old May 7, 2006 | 07:51 PM
pumpkyn's Avatar
Default Just bought a d16y8 swap, will my harness work?
I just bought a D16Y8 full swap. Will my existing harness work? I have a Honda Civic CX Hatchback. If it will work what modifications do i need to do to it? Thanks!!!
Old May 7, 2006 | 07:54 PM
The Internet Tough Guy's Avatar
Default Re: Just bought a d16y8 swap, will my harness work? (pumpkyn)
i cant answer your question, but where did you get the swap?
Old May 7, 2006 | 08:26 PM
pumpkyn's Avatar
Default Re: Just bought a d16y8 swap, will my harness work? (The Internet Tough Guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Internet Tough Guy &raquo;</TD></TR><TR><TD CLASS="quote">i cant answer your question, but where did you get the swap?</TD></TR></TABLE>
I got it from a friend in Wendover for 300, everything minus the ECU
Old May 7, 2006 | 10:10 PM
Eaglekper0046's Avatar
Add wires for vtec, also you need a p28 ecu. And a ob1 dizzy thats all I know.
Old May 7, 2006 | 10:17 PM
IM ALL BOB's Avatar
well first we need to know what year your vechile is to answer the question as
a cx from 92-95 wiring is way different than 96-00 cx..that said please look at the
FAQ section that is a sticky at the top of this forum. all the info is there..good luck
Old May 7, 2006 | 10:27 PM
props_honda85's Avatar
Default Re: Just bought a d16y8 swap, will my harness work? (Eaglekper0046)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eaglekper0046 &raquo;</TD></TR><TR><TD CLASS="quote">Add wires for vtec, also you need a p28 ecu. And a ob1 dizzy thats all I know.</TD></TR></TABLE>
Actually if you drive an obd-2 car then just go and pick up a y8 ecu and run the wire for vtec...if you use a p28 (best ecu i think hondas ever put out, imo) you'd have to find a z6 dizzy and then buy a obd-2 to obd-1 jumper harness, thats to expense to do unless you plan on running hondata, crome, uberdata, ect...
so just go and buy the ecu to fit the motor then run the vtec wire to the ecu and convert the iacv from the stock 3 wire plug thats on your motor to the 2 wire plug from the y8 (not hard to do).. im running a z6 head on my y7 block so i converted to obd-1 but if i were you i wouldnt do that unless you drive a EG
Old May 7, 2006 | 10:35 PM
pumpkyn's Avatar
Default Re: Just bought a d16y8 swap, will my harness work? (props_honda85)
Sorry it is a 1997 I knew i forgot something. So all i really need to do is run a vtec wire and thats it. I already have the ECU. are the wires already sticking out the plugs or do i need to make a new connection?
Old May 7, 2006 | 10:39 PM
run the vtec wire then change out your 3 wire iacv for the y8's 2 wire, you might want to read BaulyCivic's mini-me thread and soak up as much info as possible, it helped me through it a bit easier when i did my mini-me, only you just have to read the ecu part, he talks about a obd-1 car but fills in the blanks so obd-2 people can follow along...good luck on your car
Old May 7, 2006 | 10:51 PM
pumpkyn's Avatar
thanks, now can i do all this on my harness as the harness im using is my Auto harness as i am also doing the auto to manual swap at the same time
Old May 7, 2006 | 11:23 PM
Timmay's Avatar
it would probably be easier if you found a 96-98 EX manual harness
glad you found a swap though!!! i think i have a 96-98 EX ecu if you need
Old May 7, 2006 | 11:25 PM
pumpkyn's Avatar
Default Re: Just bought a d16y8 swap, will my harness work? (Timmay)
yeah thats what i was thinkin of getting. I got an ECU already for $35 I think i maybe able to get the harness fromt he same guy. But dammit i want this running by tomorrow night. Will changing my harness be that big of a pain?
Thanks man im glad i found one too i was getting scurred
Old May 7, 2006 | 11:31 PM
EK k kay's Avatar
Make sure the ecu you are getting is a 96-98 p2p and not a 99-00. You can used your stock harness, but you will need to run a wire for the vtec solenoid, vtec oil pressure, knock sensor, and re-wire the iacv connector. If you decide to use a y8 harness you will also have to find a y8 dash harness as well because with a y8 that is where the secondary o2 sensor plug is. Or you can run the o2 connection directly to the ecu somehow or just not plug it in and leave the cel on.
Old May 8, 2006 | 12:40 AM
pumpkyn's Avatar
Default Re: Just bought a d16y8 swap, will my harness work? (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">Make sure the ecu you are getting is a 96-98 p2p and not a 99-00. You can used your stock harness, but you will need to run a wire for the vtec solenoid, vtec oil pressure, knock sensor, and re-wire the iacv connector. If you decide to use a y8 harness you will also have to find a y8 dash harness as well because with a y8 that is where the secondary o2 sensor plug is. Or you can run the o2 connection directly to the ecu somehow or just not plug it in and leave the cel on.</TD></TR></TABLE>
could i wire the 2 o2 sensors together? or is that a bad idea? In your opnion which one would you choose, modify the one i have or just get teh harness from the ex?
If i keep mine on teh rating of 1-10 what is the difficulty of modifications?
Old May 8, 2006 | 08:57 AM
pumpkyn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pumpkyn &raquo;</TD></TR><TR><TD CLASS="quote">
If i keep mine on teh rating of 1-10 what is the difficulty of modifications?</TD></TR></TABLE>
Old May 8, 2006 | 10:54 AM
pumpkyn's Avatar
Old May 8, 2006 | 10:50 PM
pumpkyn's Avatar
Where is teh placement of the 2nd O2 seonsor i only have one on the exhaust manifold, should i just use my current manifold?
jpizzi
11
Aug 29, 2006 12:56 PM
Gauche
Aug 22, 2006 03:46 PM
hondatechS2G
Feb 13, 2006 06:30 AM
blackrex91
Aug 31, 2003 06:38 PM
LB CRX
May 31, 2003 03:48 PM
