how do i wire a sunpro mini tach to my hatch
Old May 7, 2006 | 04:57 PM
eg six's Avatar
Default how do i wire a sunpro mini tach to my hatch
i have 93 honda civic hatch single cam non-vtec (d15b7) i want to install this tach on for now until i get my jdm cluster this is a sunpro mini tach i have it half wired i just dont know where to wire my rpm signal (green) wire. my freind said to the negative end of the igniton coil but dont know wat wire it is if yall can tell me were to correctly wire it and the color of the wire that would help out alot Thanks in advance
ground (black)-to my chassis
power (red)-to my fuse box
lighting (white)-to my dimmer switch
rpm signal (green)- i dont know where
Old May 7, 2006 | 05:39 PM
eg six's Avatar
Default Re: how do i wire a sunpro mini tach to my hatch (eg six)
bump
Old May 7, 2006 | 05:45 PM
john666's Avatar
really should wire the light to the fuse box also.
(not my pic)
where it is circled thats +
one if for constant. one is ffor when lights are on and etc. just test it and u will find the right one.
now rpm just tap the blue wire behind the cluster one the left side. that wire would go into your stock tach if you have one
Old May 7, 2006 | 05:57 PM
eg six's Avatar
wat if i dont have a stock tach also i heard theres a wire that comes from the ecu that i could tap for the rpm wire is this posssible
Old May 7, 2006 | 07:43 PM
eg six's Avatar
bump
Old May 7, 2006 | 07:56 PM
boosted civic 2k6's Avatar
Default Re: (eg six)
your green wire goes directly to the blue wire on the driver side front behind the strut tower. its a BLUE WIRE that has a black rubber plug on it that goes to nothing. thats ur TACH lead. search and youll get the same thing. black n red goes to negative/ground and positive 12v wire or ur battery.
Old May 7, 2006 | 09:11 PM
eg six's Avatar
thanks anyone else know wat wire it would be from my distibutor
Old May 7, 2006 | 11:12 PM
john666's Avatar
just because your cluster doesnt have a tach doesnt mean the wire isnt there.
Old May 8, 2006 | 02:23 AM
Syndacate's Avatar
u shouldn't need to wire it to anything else...the wire for ur RPM should just be there...not connected to anything....
Old May 8, 2006 | 04:17 PM
eg six's Avatar
thanks
Old May 8, 2006 | 04:41 PM
A.E Motoring's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg six &raquo;</TD></TR><TR><TD CLASS="quote">thanks anyone else know wat wire it would be from my distibutor</TD></TR></TABLE>
its a BIG blue wire solid color
Old May 8, 2006 | 04:45 PM
eg six's Avatar
would i tap the green wire into the connection coming out of the dizzy or the connection that connects to the dizzy
Old May 8, 2006 | 04:47 PM
out of the dizzy, the plug thats on the dizzy
Old May 8, 2006 | 04:56 PM
eg six's Avatar
thanks spnfedeh finally i can install it
Old May 8, 2006 | 05:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg six &raquo;</TD></TR><TR><TD CLASS="quote">thanks spnfedeh finally i can install it</TD></TR></TABLE>
Old May 8, 2006 | 05:53 PM
SicilianSpeed42's Avatar
the blue tach signal wire runs all the way to your cluster, you can tap into the blue wire on the plug farthest to the drivers side of your cluster
pair8hd
Dec 1, 2007 03:44 PM
bbhockey19
10
Jul 11, 2006 09:10 PM
Tippyman
Apr 22, 2006 04:05 PM
Chiovnidca
Feb 16, 2006 03:09 AM
civiclxb16a
Apr 30, 2005 09:37 PM
