Car wont start. No spark
Old May 7, 2006 | 04:30 PM
standbackimapro's Avatar
Default Car wont start. No spark
Well for some reason my car wouldnt start today, it turned over and everything like it wanted to start, so i opend up the hood, stuck a screw driver in one of the spark plug boots and held the metal on the screw drive to the nut on top of the valve cover...
Looked like i wasnt getting any spark...
What could it be?
the ignitor? or somthing else?
Old May 7, 2006 | 04:42 PM
hondadude's Avatar
Default Re: Car wont start. No spark (standbackimapro)
on your 82 accord you should check the connection to the voltage regulator on the passenger side fender well; also there is a service bulletin about the vacum dashpot for the vent controls that might need to be resealed.
Old May 7, 2006 | 04:57 PM
lalo's Avatar
HAVE U CHECK THE ALTERNATOR OR THE DISTRIBUTOR..
Old May 7, 2006 | 05:01 PM
Its a 90 Accord
we Attatched a jump box to it, so either way it should have started,
I get power to the accesories in the car...
Old May 7, 2006 | 05:52 PM
Ross 2.0's Avatar
In a Junkyard near you.
You should really consider changing your screen name man. Have you inspected the coil and igniter?
Old May 7, 2006 | 05:58 PM
BLKFLSH's Avatar
Default Re: (standbackimapro)
Here's a link that might help. Good luck
http://techauto.te.funpic.org/ignition.php
Old May 7, 2006 | 06:00 PM
2fast2jewish's Avatar
that sucks
Old May 7, 2006 | 06:05 PM
BLKFLSH's Avatar
Default Re: Car wont start. No spark (2fast2jewish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast2jewish &raquo;</TD></TR><TR><TD CLASS="quote">that sucks </TD></TR></TABLE>
Very helpful, thanks.
Old May 7, 2006 | 06:10 PM
Ross 2.0's Avatar
welcome to h/t. Please be sure to read the rules and regulations you just agreed to.
Post whoring is against the rules. If you want to survive around here please be sure to try to adhere to the rules.
Old May 7, 2006 | 10:24 PM
HONCORD's Avatar
Default Re: Car wont start. No spark (MooGoCow3)
I would check if you gettin a spark on the coil. If you do check cap and rotor n go down the line.
Alternator wont give you spark loss, its just keeping tha system charged.
Old Jun 13, 2006 | 05:41 PM
berettagtz117's Avatar
Default Re: (BLKFLSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote">Here's a link that might help. Good luck
http://techauto.te.funpic.org/ignition.php</TD></TR></TABLE>
Very nice link!!!
Old Jun 13, 2006 | 05:44 PM
Ross 2.0's Avatar
Glad you found the link helpful but there was no need to bump the thread.
octodigitus
Apr 24, 2017 06:55 AM
sikwitit
Apr 10, 2008 05:53 PM
keng
Jul 6, 2005 07:27 AM
DougNuts
Jun 26, 2005 02:50 PM
MetalKill
10
Jan 30, 2003 07:42 AM
