need help!!!! 5 lug on an ek
Old May 7, 2006 | 04:18 PM
madsnoopy714's Avatar
Default need help!!!! 5 lug on an ek
im just wondering has anyone had a problem with the type r ebrake cable to fit in an EK..i tried to install my 5 lug yesterday and it seemed like the itr ebrake cable is short.. do i need to get the si or ex ebrake cable? the second question do i need to change the master cylinder to a gsr? because my brake is soft than my stock brake... and yea has anyone have a problem with the type r brake line? because it seem like it is to long for my ek.... i will appreciate your help.... thanks guyz...
Modified by madsnoopy714 at 7:35 PM 5/7/2006
Old May 7, 2006 | 05:55 PM
mek9fast's Avatar
Default Re: need help!!!! 5 lug on an ek (madsnoopy714)
im using a si mc and si lines
Old May 7, 2006 | 06:35 PM
bump
Old May 7, 2006 | 07:52 PM
JDM-EJ698's Avatar
I used SI E-brake cables and lines.as for MC I still have my stock one n work just fine!
Old May 8, 2006 | 10:02 AM
Default Re: need help!!!! 5 lug on an ek (shiftknob85)
Old May 8, 2006 | 10:34 AM
Targa250R's Avatar
be professional
You have to use '99-00 Si e-brake cables, and you'll want to upgrade the master cylinder to a 15/16" or a 1" unit.
Old May 8, 2006 | 11:21 AM
EricUSC's Avatar
Default Re: need help!!!! 5 lug on an ek (Targa250R)
My setup is as follows:
E-Brake cables: 99-00 Si
Brake lines: 99-00 Civic Si
Master cylinder: ITR
Booster: ITR
Proportioning valve: 99-00 Si
I believe this is the best setup. E-brake cables and brake lines from an Integra might fit, but they may be too long or too short. Civic EX brake cables will not be a direct fit, since the EX has rear drums. A stock master cylinder and booster is fine, but since you are using ITR brakes, it would be optimal get the matching components.
When I first installed the above setup, the brake pedal felt soft, but the mechanic told me that it will return to normal after few weeks of driving. After a few weeks, the brake pedal did return to normal.
Old May 8, 2006 | 11:59 AM
Default Re: need help!!!! 5 lug on an ek (EricUSC)
do i need a booster and the Proportioning valve?
Old May 8, 2006 | 12:39 PM
Old May 8, 2006 | 01:30 PM
johnecon2001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madsnoopy714 &raquo;</TD></TR><TR><TD CLASS="quote">do i need a booster and the Proportioning valve?</TD></TR></TABLE>
Yes.
Old May 8, 2006 | 03:55 PM
Default Re: need help!!!! 5 lug on an ek (johnecon2001)
can i use my stock booster and proportional valve...
Spitz911
14
Aug 3, 2012 07:11 AM
dc4teg95
Apr 7, 2010 08:55 AM
Pho Real
May 14, 2002 08:53 PM
