3rd grind. gm synchromesh?
Old May 7, 2006 | 10:14 AM
lv6l's Avatar
Default 3rd grind. gm synchromesh?
94 civic hatch. jdm d16a. si tranny.
i have a 3rd gear grind at high rpm only. i tried maxing out 2nd gear and slowly putting it in 3rd with clutch fully to the floor, still grinds. i'm pretty sure my syncos are gone so i would like advice on ways to fix this problem before it gets wrose or will it ever get so bad i can't even go in 3rd?? i dont mind the grind if it will never effect my tranny but if it'll slowly get wrose then i might as well try somthing now. i herd putting gm synchromesh in my tranny will help the grind, iono if thats true. advice please, thanks.
Old May 7, 2006 | 10:16 AM
wrx'n you's Avatar
Default Re: 3rd grind. gm synchromesh? (lv6l)
gm synchro will help but wont cure it. its only a band-aid...
Old May 7, 2006 | 10:27 AM
lv6l's Avatar
how mcuh will it help? will it actually work and not grind in 3rd anymore for a period of time? or will it still grind but just putting in gm synchromesh will help hold my tranny together.
Old May 7, 2006 | 10:35 AM
dthug's Avatar
Default Re: (lv6l)
bump i want to know this to my gsr tranny does the same thing
Old May 7, 2006 | 10:37 AM
plz turn off trial user's Avatar
Default Re: (dthug)
whats a d16a?
Old May 7, 2006 | 03:27 PM
lv6l's Avatar
Default Re: (civicfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicfast &raquo;</TD></TR><TR><TD CLASS="quote">whats a d16a? </TD></TR></TABLE>
japanese version of the usdm d16z6.
Old May 7, 2006 | 04:26 PM
Default Re: (lv6l)
rare?
Old May 7, 2006 | 06:01 PM
drift4jesus's Avatar
go to autozone and get 3 $5 bottle of pennzoil syncromesh fluid. it takes about 2 and 1/4 to fill a bseries trans.
Did this in my 150k gsr trans and fixed the prob.
Old May 7, 2006 | 11:08 PM
lv6l's Avatar
yes. rare. most people get it confuse with the usdm d16a6 off the crx. but its not.
Old May 8, 2006 | 04:02 AM
JSPECSIR's Avatar
Default Re: (lv6l)
synchro mesh fixed my 3rd gear grind. been over a year no grinds!
Old May 8, 2006 | 04:05 AM
t0p_sh0tta's Avatar
Default Re: (5THGENSI)
The fluid fixes nothing. Your synchros are still worn, and the grind will come back.
Old May 8, 2006 | 07:28 AM
lv6l's Avatar
how often do i have to add the synchromesh? do i change it like how i would change tranny fluid?
Old May 8, 2006 | 08:02 AM
t0p_sh0tta's Avatar
Default Re: (lv6l)
Yes. I don't know what the fluid change intervals are. I'd assume 12 months or 30,000 miles (sounds a bit high).
I change everything annually.
Old May 8, 2006 | 05:14 PM
JSPECSIR's Avatar
Default Re: (t0p_sh0tta)
maybe the fact that the synchro mesh is a thinner viscosity than honda mtf it allows the synchros to spin more freely allowing the to work properly. if so many hondas do it maybe the honda mtf is just simply the cause because it is to thick. food for thought for all the haters..... you can say what you want but my tranny dont lie take out honda mtf put in synchro mesh no more grinding for over a year. as i see it problem fixed.
Old May 8, 2006 | 05:19 PM
BLUE EH3's Avatar
Help we my pennies
my 3rd grind if dont hold the clutct to floor all the way.. basliy only whe i racing... i gotta buy a diif for my ls tranny and sell the b16
Old May 8, 2006 | 05:26 PM
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicfast &raquo;</TD></TR><TR><TD CLASS="quote">rare?</TD></TR></TABLE>
Very rare indeed if that's what he has. Supposedly has 140hp, making it the most powerful sohc motor. Again this is what I've heard, it's pretty rare so there's not solid info.
Old May 8, 2006 | 10:04 PM
lv6l's Avatar
Default Re: (fast95eg9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg9 &raquo;</TD></TR><TR><TD CLASS="quote">
Very rare indeed if that's what he has. Supposedly has 140hp, making it the most powerful sohc motor. Again this is what I've heard, it's pretty rare so there's not solid info.</TD></TR></TABLE>
finally someone that knows something about my motor. i have so many people told me i got a crx motor. sigh. hehe
Old May 9, 2006 | 03:02 AM
lv6l's Avatar
what brand of syncromesh is good for my car?
Old May 9, 2006 | 03:18 AM
wrx'n you's Avatar
Default Re: (lv6l)
gm sychromesh friction modified or pennzoil synchromesh from autozone.
Old May 9, 2006 | 03:35 AM
Kangolbrand's Avatar
I got the same problem on my gsr.... only grinds on 3rd when im racing or shifting over 6k or higher. im going try that pennzoil syncromesh fluid. Thanks for the info drift4jesus
Old May 9, 2006 | 03:49 AM
lv6l's Avatar
is this a common problem for honda tranny to grind in 3rd? cuz my old gsr had the exact same problem.
btw. what are some good brands of syncromesh for honda manual transmission?
Old May 9, 2006 | 03:52 AM
t0p_sh0tta's Avatar
Default Re: (lv6l)
It's called G.M. Syncromesh for a reason.
Contact your local G.M. dealer.
Old May 9, 2006 | 04:39 AM
lv6l's Avatar
Default Re: (drift4jesus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift4jesus &raquo;</TD></TR><TR><TD CLASS="quote">go to autozone and get 3 $5 bottle of pennzoil syncromesh fluid. it takes about 2 and 1/4 to fill a bseries trans.
Did this in my 150k gsr trans and fixed the prob.</TD></TR></TABLE>
drift4jesus suggested to get pennzoil syncromesh. i never used this before so i was just wondering if different brands make a difference.
Old May 9, 2006 | 04:47 AM
t0p_sh0tta's Avatar
Default Re: (lv6l)
Probably not. Why don't you try it and find out. Last time I picked up Syncromesh, I paid about $7 per quart (you need 2 for d-series).
Old May 10, 2006 | 01:33 PM
BLUE EH3's Avatar
Help we my pennies
why does 3rd grind in alot of cars and not 1.2.4.5
