EG Pedal Set in a EK????? Auto to manual conversion
I went looking for a EK pedal set today for my auto to manual conversion but all I found at two junkyards was a 93 EG Coupe. Does anyone know if the pedal set from this would bolt up in an EK? I would imagine the master cylinder would because those are kind of a standard but I'm more concered down below with the pedals. Also I checked my firewall and I dont see the blocker plate for the master cylinder.
Any guess on why I can't see the hole for it on my firewall? Do I have to cut the firewall material back or something?
It is in the same place right (On EG and EK)?
ROFL I found mine tonight and the clutch pedal is all installed, the previous owner installed some sort of aftermarket cruise control and used the the hole for a wiring path. He then used a ton of black caulk to seal it off, it was a bitch to clean up but it's all installed now.
ScottEK
Apr 30, 2006 05:47 PM
