are drums trailing arm the same as rear disc?
just the trailing arm itself and not the brake components. Are they the same? the trailing arm i have from an integra i think are bent, but i still have my old trailing arm. Would i be able to swap out the brake parts to it? thanks
no not really...
the trailing arms that are equipped with drums don't have the mounting point for the calipers...
you will need to make a plate that you can attach to where the drum mounts to the trailing arm...to attach the caliper on to
http://cgi.ebay.com/ebaymotors...ZWDVW
will this fit an integra with rear disc? i know the description says other wise, but it looks like it will. can anybody help me. I doubt the seller knows.
I believe the are the same, the reason I say this is because you don't need the trailing arm to put disc on a car with drums, it may be easier but it is not nessecary to have the trailing arms.
search drums to disc, if you find that you can put disc brakes on a car with drums without the trailing arm then you will know for sure
yes they are the same... THE HUB is different.. i used drum trailing arms and put the rear disc hub.. the thing that holds the bearings and all that on it and it also has the spot to hold the caliper..
its a bitch to change out the torx bolts tho.. i bent 8 bits
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic »</TD></TR><TR><TD CLASS="quote">yes they are the same... THE HUB is different.. i used drum trailing arms and put the rear disc hub.. the thing that holds the bearings and all that on it and it also has the spot to hold the caliper..
its a bitch to change out the torx bolts tho.. i bent 8 bits</TD></TR></TABLE>
Finally someone who knows what the hell their talking about
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 »</TD></TR><TR><TD CLASS="quote">no not really...
you will need to make a plate that you can attach to where the drum mounts to the trailing arm...to attach the caliper on to</TD></TR></TABLE>
^^^^ don't spread false info if you if you don't know WTF you're talking about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mingbling96 »</TD></TR><TR><TD CLASS="quote">http://cgi.ebay.com/ebaymotors...ZWDVW
will this fit an integra with rear disc? i know the description says other wise, but it looks like it will. can anybody help me. I doubt the seller knows. </TD></TR></TABLE>
Somebody, please comment on this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet »</TD></TR><TR><TD CLASS="quote">
beat me to it...
the hub info can be found burried in the FAQ as well.
</TD></TR></TABLE>beat me to it...
Timberland237
Apr 11, 2008 01:16 PM
snapcase318
Jun 9, 2004 09:06 AM
