Mine me Timing. SEARCHED*
Ok this is my question. Has anyone gotta a minime (A6block/Z6Head) to run proper timing with a D15B7 dizzy? Have this setup in my EG hatch. Im 99.9% sure my TDC is correct and belt is on good. My idle Is not bad at around 600. Dizzy is fully advanced and timing is only around 0deg. Anyway to correct this Without a Z6 Dizzy and adjustable cam gear? Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darkane »</TD></TR><TR><TD CLASS="quote">Ok this is my question. Has anyone gotta a minime (A6block/Z6Head) to run proper timing with a D15B7 dizzy? Have this setup in my EG hatch. Im 99.9% sure my TDC is correct and belt is on good. My idle Is not bad at around 600. Dizzy is fully advanced and timing is only around 0deg. Anyway to correct this Without a Z6 Dizzy and adjustable cam gear? Thanks.</TD></TR></TABLE>\
From what I've been told, it's a shitload easier to just get a z6 dizzy. For your **** to run properly requires that you advance your b7 dizzy beyond the slots on the head, which then, unless you really felt like wasting time with a timing light, an buying whatever parts like washers, nuts and bolts to make the dizzy stable, is stupid.
Yeah exactly. Im trying to find a Distrbiutor locally here but untill then want to get it to run better. Thanks for the response.
teamrpm2
19
Jan 28, 2020 08:41 PM
