quick question
Old May 6, 2006 | 05:08 PM
ImXposed's Avatar
Needs $$ for a Hooker
Default quick question
i just installed a twin loop replica muffler, and there is a little bit (alot) of rattling in the middle rpms. around 3.5 k. i'm assuming that the vibrations from the exhaust are knocking against some part of the chassi or suspesion or something. i'm thinking i could wrap the piping with some kind of exhaust wrap or header wrap or something that may be able to quiet it. can i use header wrap? is it expensive? my other alternative is to use surgical tape, that somewhat thin fabric tape. obviously im going to get someone who will tell me that they would like to watch my car go up in flames... but thats why im asking. i just want something that will cease the rattling. any suggestions?
Old May 6, 2006 | 05:10 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: quick question (ImXposed)
Check the heat shield on top of the catalytic converter for the rattle. Header wrap is not a good idea, as it will most likely cause your exhaust to corrode. The regular fabric tape will catch on fire.
Old May 6, 2006 | 06:18 PM
ImXposed's Avatar
Default Re: quick question (Dogginator)
know for a fact its not that cat, only piece of exhaust i touched was the axelback section. i just need a way to quiet it down. only rattle through 3-4k rpms. after that its all golden. might take it to a muffler shop and have them weld a new piece of piping on, that may be the cause, but around that much the muffler is vibrating at just enough to graze something under there and its loud as hell and i don't like it haha.
Old May 6, 2006 | 07:52 PM
ImXposed's Avatar
figured it out. THIS PIECE:
is buzzing against THIS PIECE:
cause: shitty weldup, hangers are a little too far to the left of the car, needs to be about a half in or an inch over to the drivers side, should fix problem. should i be able to bed these myself using hammer or something? the exhaust is a temp. I just want it to stop buzzing.
Old May 6, 2006 | 07:55 PM
VTteg's Avatar
You bought a nice twin loop muffler just as a temporary exhaust?
Old May 6, 2006 | 07:56 PM
ImXposed's Avatar
naw man. I traded my stock + a tidbit of cash for it + a replica ITR strut bar. Its a used axelback with a pretty beat weldup job.
Old May 6, 2006 | 08:20 PM
ImXposed's Avatar
some help out perhaps?
Old May 6, 2006 | 08:53 PM
Johnny Gasparini's Avatar
I didn't ask for a dime.
Default Re: (ImXposed)
Face it, you bought an inferior product and this is the price you pay when you decide to save a few bucks. Your best bet would be to ditch that p.o.s. and invest in a product that was tested to make sure none of the things you are experiencing occur.
Old May 6, 2006 | 08:59 PM
ImXposed's Avatar
it is a js racing muffler that whoever welded the axelback section on didn't measure it up correctly, not inferior product, inferior work to get it put on. cut corners etc. Unfortunately you were not the least bit helpful to my cause. did i not mention this muffler was a temp? I have plans for my car, this is just appeasing my lust for parts along the way so I don't go bankrupt right off the bat. Now i was going to try to be polite, but i'm sick of people here giving me bullshit reponses that are absolutely not helpful at all. So if you don't have anything HELPFUL to say regarding TOPIC and not what i SHOULD have done... you can leave the thread and DON"T POST!!!
Old May 6, 2006 | 09:11 PM
Wait... first you said:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImXposed &raquo;</TD></TR><TR><TD CLASS="quote">i just installed a twin loop replica muffler</TD></TR></TABLE>
Then you said:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImXposed &raquo;</TD></TR><TR><TD CLASS="quote">it is a js racing muffler</TD></TR></TABLE>
So which is it? How the hell can we help if you don't know what you have?
Old May 6, 2006 | 09:13 PM
ImXposed's Avatar
the js racing muffler is a replica of the mugen twin loop muffler am i correct?
Old May 6, 2006 | 09:23 PM
I honestly don't ever recall there being a J's Racing twin loop. IIRC, Mugen was the first and shortly after, there was DC (different design). Then all the replicas entered the market.
To answer your question, I would have a muffler shop fix your problem. I do not recommend wrapping the muffler with anything. There is nothing I can think of that will reduce the noise and won't catch fire.. You will have to have them reposition the hangers to clear the chassis. In doing so, the muffler may end up hanging alittle lower than you may like.
Old May 6, 2006 | 09:38 PM
ImXposed's Avatar
Thank you, that was actually the most helpful piece of advice i've had yet. pretty much what i was going to end up doing anyway but just wanted to make sure. thanks.
Old May 6, 2006 | 09:41 PM
ImXposed's Avatar
its SNL, my bad. heard js racing somewhere.
4doorteggy
Aug 1, 2009 07:32 AM
lumnite
Nov 26, 2007 05:50 PM
greasemonky50
16
Jan 21, 2006 06:28 AM
Itr001
Oct 28, 2005 07:24 AM
