somewhat technical sleeve ?
Old Apr 10, 2002 | 08:00 AM
B pwr's Avatar
Default somewhat technical sleeve ?
jgs - iron ductile,closed deck
goldeneagle- assuming iron, buttressed opendeck
darton/aebs - spincast nodular iron, closed deck
do the piston rings seat better than thee other, considering how theyre made? or its all the same, dont matter.
im looking at the goldeneagle, therye butrresed and opendeck, in my opinion,
i would belive it keeps the upper cylinders cooler than closedeck.Is thyere a wesite for them?
ill be sleeving a b18c, with bigbore pistons(na) this year-dailydriver. So does anybody have any 1st hand experince with any one of these,especially dailydriven streetcars? any recommendations welcome.
thanx
[Modified by crxpwr, 5:08 PM 4/10/2002]
Old Apr 10, 2002 | 08:09 AM
Spade's Avatar
Default Re: somewhat technical sleeve ? (crxpwr)
http://www.goldeneaglemfg.com
$1300 for a sleeve, bore, hone, and forged pistons.
Edit Iron ductile.
[Modified by Spade, 9:09 AM 4/10/2002]
Old Apr 10, 2002 | 08:11 AM
dasher's Avatar
http://www.goldeneaglemfg.com/sleeves.htm
The sleeves are open decked and made of Nodular Ductile Iron...
They do some of the best work in the business from what I hear ...
Overboost has an article on them in their tech section...
You are right in the assumption that a open deck configuration helps cool the cylinders better than a closed deck... that is why GE goes to the trouble of removing your old sleeves and completely replacing them with Iron ....
cost is 750.00 dollars ... will cost more (look above) for pistons...
Darton does some fine work also...
[Modified by dasher, 5:18 PM 4/10/2002]
Old Apr 10, 2002 | 08:17 AM
dasher's Avatar
Default Re: somewhat technical sleeve ? (dasher)
here is another thread about sleeves...
https://honda-tech.com/zerothread?id=160701
Old Apr 10, 2002 | 09:06 AM
rainforest's Avatar
dartons overheat. not enough water jacket area. get golden eagle
Old Apr 10, 2002 | 12:10 PM
B pwr's Avatar
Default Re: somewhat technical sleeve ? (rainforest)
Yeah, i checked that thread and GE website. Excellent, i will definelty be going to Goldeneagle.
those above who responded with a response(spade,dasher,rainforest) many thanx !!
kgreenhaw
Aug 3, 2012 12:24 AM
namm
Dec 8, 2006 08:13 AM
H22Luda720
Mar 20, 2006 05:35 AM
tooqwik1
Feb 18, 2003 11:51 AM
B18C4-T
Nov 24, 2002 09:30 AM
