90 accord with 228,000 miles wit a couple of problems
Old May 6, 2006 | 01:58 PM
zeppdogg's Avatar
Default 90 accord with 228,000 miles wit a couple of problems
yea my moms just brought a 90 accord ex from sum *** whole for 1300 without letting me look at it first the sport shift light is blinking and i drove it and realize that it shifts from 1st and skips all the way to 4th i also noticed that there was no engine breaking when i threw it down to 1 when i throw it in 2nd you can feel it a little bit engine of breaking and theres nothing happening in 3rd. the other problem is that it smokes (blue smoke) when u floor it the smoke doest start tell u hit 5 grand and up i know that its oil burning i talked to tech about and he said its prob oil seals and stuff so he gave me sum leak stopper/smoke stopper and recommend to use 20 -50w oil so it'll reduce oil by passing wateva seals if it doesnt stop i guess we gotta rebuild the motor.
Old May 6, 2006 | 02:06 PM
hondadude's Avatar
Default Re: 90 accord with 228,000 miles wit a couple of problems (zeppdogg)
Jumper the Blue 2 pin connector under the glovebox above the kick panel; turn on the key and count the flashes of the 'S' light. It sounds like a bad solenoid on the trans
Old May 6, 2006 | 06:21 PM
YeuEmMaiMai's Avatar
Default Re: 90 accord with 228,000 miles wit a couple of problems (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">Jumper the Blue 2 pin connector under the glovebox above the kick panel; turn on the key and count the flashes of the 'S' light. It sounds like a bad solenoid on the trans</TD></TR></TABLE>
In addition to what he said......
Also check the condition of the trans fluid....now might not be a bad time to change out all of the various fluids such as
brake
coolant
engine oil
trans fluid
also not a bad time to visually inpect the car either.
If the car is in descent shape you might make it to 350-400K plus miles
P.S. might also want to invest in some English language skills so you appear to be more intelligent.......
Old May 7, 2006 | 12:11 AM
BigPeterRSX's Avatar
i have a 1990 honda accord coupe i had blue smoke. head gasket was leaking sealed now its normal
Old May 7, 2006 | 12:13 AM
accord-pro's Avatar
wow sounds like you got issues,,,,,,,,,,
before rebuilding the motor i would replace the valve seals ...
and forget all that mickey mouse leak stopper ,,it does not work ..
if you do need to rebuild the motor ,,you will never get out of the car what you will put into it..
And we do not know yet what is the problem with the tranny , waiting for you to post the code ,,
Old May 7, 2006 | 05:23 AM
spartan6's Avatar
Dude, swap in an H22 and call it a day
Old May 7, 2006 | 08:35 AM
zeppdogg's Avatar
yea when i fired it up yesterday and drove it i noticed that the speedometer was jumping up and down then later it started working normal again now theres a new problem right seat belt aint workin no more lololol and the rear right window wont go all the way up or down but i think its grit down in the door or sumtin damn the problems just keep building up lololololol
Old May 7, 2006 | 05:08 PM
standbackimapro's Avatar
1300 Dollars? The KBB private Party on that car is 800 dollars, and thats in excellent shape...
Old May 7, 2006 | 05:20 PM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: (zeppdogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeppdogg &raquo;</TD></TR><TR><TD CLASS="quote">yea when i fired it up yesterday and drove it i noticed that the speedometer was jumping up and down then later it started working normal again now theres a new problem right seat belt aint workin no more lololol and the rear right window wont go all the way up or down but i think its grit down in the door or sumtin damn the problems just keep building up lololololol</TD></TR></TABLE>
Well you probably found the reason for the blinking S light. Your speed sensor is probably taking a crap at the moment. So your TCU has no idea what gear to tell the trans to shift to.
But as far as the overall value of the car compared to the problems you described it doesn't sound like it was too good of a deal.
And like Accord-pro said. Don't bothor with the crappy leak stoppers. That just makes it worse.
Old May 8, 2006 | 12:58 PM
zeppdogg's Avatar
would it be cheaper to buy or trade for a rebuilt motor instead of rebuilding the motor thats in it now
Old May 8, 2006 | 01:00 PM
zeppdogg's Avatar
Default Re: (MooGoCow3)
at the auto auctions in my area it would have went for $1700-2300
Old May 8, 2006 | 03:30 PM
knucklehead11's Avatar
Default Re: 90 accord with 228,000 miles wit a couple of problems (accord-pro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord-pro &raquo;</TD></TR><TR><TD CLASS="quote">wow sounds like you got issues,,,,,,,,,,,</TD></TR></TABLE>
Yeah not just his car either. Sounds like he needs to head back to English class in middle school.
Old May 8, 2006 | 08:25 PM
ck123's Avatar
how do you seal the gasket if its leaking?
Old May 9, 2006 | 11:35 AM
zeppdogg's Avatar
yea i just got sum horrible prices for rebuilding the block prices range from 2500-4600 witout labor i gotta price quote for buying a rebulit motor for around 600 and another 600 for labor
kirlous k
Jul 4, 2018 11:48 AM
j4s0n1337
Aug 17, 2011 12:07 AM
emosun
Feb 26, 2010 05:29 AM
hollar at my v6
Jul 23, 2005 05:27 PM
jstyle711
Dec 8, 2002 04:38 PM
