Clutch switch plug splicing...
Old May 6, 2006 | 01:37 PM
RustyE.G.'s Avatar
Default Clutch switch plug splicing...
I just posted about this not long ago, but I still haven't gotten where I need to be. If anyone's done an auto to manual conversion on a e.g. ex, you should be able to tell me what I need to know. My car is already a stick e.g. dx, but I put power doors on it. I didn't want some stupid aftermarket kit, so I got a cabin harness from an ex, but it was an automatic. I have the ground for the cluth plug spliced on in the proper place, but I don't know where to splice on the other wire. This is because on the dx harness it goes to a relay. Problem is on the ex harness, this portion is a subharness that connects to two relays, I'm guessing one is for the sunroof. I know it's supposed to run to one of the two relays somehwere. So, if you have done the conversion, you could tell me where you spliced this wire on at, or if you own an ex that is a stick maybe you could peep it out under your dash for me. I need to get my car reassembled asap, so any help would be greatly appreciated!
Old May 8, 2006 | 03:04 PM
RustyE.G.'s Avatar
Default Re: Clutch switch plug splicing... (e.g.meep)
BUMP, to my understanding I could also mess with the neutral safety switch to get my car started.
Old May 9, 2006 | 05:41 PM
RustyE.G.'s Avatar
Bump, lets not be lame people...
Recyclingfreak
Nov 5, 2017 03:33 PM
Rekkless
Sep 13, 2011 11:07 PM
ilikejesus
May 7, 2009 09:43 PM
TurtleEgg95
Jun 7, 2007 08:51 PM
flatblk
Nov 4, 2006 08:54 PM
