some help please
You're A/C drain is clogged. There is a drain tube underneath of the passenger side of the car right in front of the firewall. Spray a quick jet of air in the tube and it will release the blockage. You'll know if you got it right cause water will pour out.
93acclude is right but unfortunately the air gun normally won't remove the debris from the evaporator case, It just repositions it . It may end up back in the drain again and cause the same problem. Watch where you use the fresh air portion of you climate control. This is the mode that allows debis to get into the evaporator case.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PETC »</TD></TR><TR><TD CLASS="quote">Could it possibly be the heater core?</TD></TR></TABLE>
is it green and smells sweet?
This problem only requires that you look under the glove box to see where it's leaking from.
nramil
Jul 23, 2008 08:41 PM
SuperCivic
Apr 22, 2004 03:27 AM
