vtec problems like whoa!
d16z6 head d15 block, everytime its supposed to hit vtec the check enging light comes on showing codes 21 and 22 (21 VTEC spool solenoid valve 22 VTEC pressure valve) WTF is all that shiz? do i need a new solenoid?????????? HELP i need vtec soon before i bore myself to death!
check your ground wire on the solonoid, i had problem similiar to this one an it was cuz my ground wire on the side of the solenoid had came off.. It was a simple fix but worse case scenario is you'll need a new switch an solenoid, big woop u can get'm at junkyard for under 50 bucks... Good Luck..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nutball72 »</TD></TR><TR><TD CLASS="quote">HELP i need vtec soon before i bore myself to death!</TD></TR></TABLE>
Jesus Christ man...relax....
lshatch1.8
10
Nov 28, 2005 08:51 AM
