i get on it, then the temp goes up
Old May 5, 2006 | 08:28 PM
DA is best's Avatar
Default i get on it, then the temp goes up
every time i get on it about 5 seconds later the water temp goes all the way up and stays there until i rest my car for about 5-7 min whats the problem, and my fan is working, i have no coolent leaks because i did a pressure test about 4 days ago and nothing was leaking, do i need to reserfice my head or what
Old May 5, 2006 | 08:32 PM
94_DC4's Avatar
Default Re: i get on it, then the temp goes up (derek21)
Check you thermostat. Its probably failing.
Old May 5, 2006 | 08:46 PM
8200RPM's Avatar
local hippie
Its possible the head is lifting. Whats your setup?
Is your coolant reservoir full after this happens?
Old May 5, 2006 | 08:53 PM
DA is best's Avatar
i just put in a new thermostat about a month ago, um the only mod i have is intake and my reservoir is at full when i checked it
Old May 5, 2006 | 08:54 PM
DA is best's Avatar
i have a b18a
Old May 5, 2006 | 08:56 PM
8200RPM's Avatar
local hippie
Default Re: (derek21)
Yea I mean I can only offer minimal advice as I am not a mechanic or anywhere near it but from personal experience... when I boosted my sohc I had the same issue when my head was lifting. Maybe your hg is blown?
Old May 5, 2006 | 09:07 PM
DA is best's Avatar
yeah i was thinking that to, sucks because it takes so much time to do it
Old May 5, 2006 | 09:13 PM
8200RPM's Avatar
local hippie
yep
Old May 6, 2006 | 04:05 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by derek21 &raquo;</TD></TR><TR><TD CLASS="quote">i just put in a new thermostat about a month ago, um the only mod i have is intake and my reservoir is at full when i checked it</TD></TR></TABLE>
New parts can be bad as well. You could also have blockage in your radiator. When the temperature spikes, is your radiator really hot? Does the heater blow really hot? (Turn it on to check.)
radeon
Sep 9, 2009 04:55 AM
Chuethou_b18c5
Mar 15, 2007 10:46 AM
bostoncal
Oct 21, 2005 09:03 PM
civictypenos
Aug 6, 2004 07:02 AM
dbman96
Oct 27, 2001 08:05 AM
