need help
i am throwing two check engine lights one for the throttle position sensor and the other for camshaft postion sensor , my idle is rough and it surges a little bit and it almost comes close to dieing but i put a new sensor on throttle body because it was broken when received the motor do you have to do any adjusting to sensor, and for the camshaft postion sensor if it is bad would it make my timeing off because i tryed to set it a couple of times but it is still it is off, i have no ide what this motor been through i bought it and it wouldent start come to find out it was way off time from the cams, we get it better than what it was and finally got it started and tryed it a coulpe more times and still could not get it right ,
