soft gas pedal....adjusted throttle cable..what else?
Old May 5, 2006 | 10:02 AM
97civic123's Avatar
Default soft gas pedal....adjusted throttle cable..what else?
after swapping a b16a2 into my 96 ek..using the b16 throttle cable. the gas pedal is very soft. you can press it, and feel like it's pressing nothing. I tried adjusting the throttle cable nuts under the hood but didn't do much. any suggestions?
Old May 5, 2006 | 10:11 AM
honda_civic1's Avatar
is there a lot of free play in the cable??
Old May 5, 2006 | 10:27 AM
Luserkid's Avatar
Default Re: (honda_civic1)
Was you civic a EX? If so use that cable.
Old May 5, 2006 | 02:05 PM
97civic123's Avatar
Default Re: (Luserkid)
no it's a 96 dx. i was told the dx cable was too short? yes when i adjusted the cable, it was pretty loose.
Old May 5, 2006 | 02:08 PM
Luserkid's Avatar
Default Re: (97civic123)
Opposite, DX is way to long becuase of the funky manifold. Thats odd that you have alot of play, i think you have the wrong throttle cable. Try getting your hands on EX, another B16, LS, Type R, any 92-95 throttle cable. What bracket are you using?
Old May 5, 2006 | 03:34 PM
if its loose then that way its doing what its doing, just adjusted right.
Old May 5, 2006 | 05:40 PM
97civic123's Avatar
well first i tried to give it some play, then i tightened it, but the gas still feels soft. it responds when i accelerate, but it's just soft feeling... is there any other place i can make adjustments?
Old May 5, 2006 | 06:14 PM
MasterKwan's Avatar
You get someone to watch the throttle body, you step on the gas and they tell you how much the throttle opened. If it's not opening all the way, you tighten the cable some more. Honda has a real procedure for it but, it's not that hard to do by feel. If you can't get it tight enough, you might need to get a different bracket (bolts to intake manifold).
Old May 5, 2006 | 06:40 PM
97civic123's Avatar
Default Re: (MasterKwan)
that's what i was doing. the bracket is the stock b16 bracket..one with 2 bolts. i never removed it.
Old May 5, 2006 | 09:48 PM
MasterKwan's Avatar
So, does the throttle butterfly open all the way when you floor the pedal?
Old May 5, 2006 | 10:03 PM
97civic123's Avatar
yep
19992civichatch
Jan 10, 2007 06:27 AM
delamission
Jan 21, 2006 03:15 PM
Orangedragone
Nov 4, 2005 08:53 AM
jaycapz
15
Jan 25, 2005 07:00 PM
illi Adik
Oct 28, 2002 01:17 PM
