soft gas pedal....adjusted throttle cable..what else?
Old May 5, 2006 | 10:01 AM
97civic123's Avatar
Default soft gas pedal....adjusted throttle cable..what else?
after swapping a b16a2 into my 96 ek..using the b16 throttle cable. the gas pedal is very soft. you can press it, and feel like it's pressing nothing. I tried adjusting the throttle cable nuts under the hood but didn't do much. any suggestions?
Old May 5, 2006 | 10:44 AM
crxsirvtec's Avatar
Default Re: soft gas pedal....adjusted throttle cable..what else? (97civic123)
first of all... you have a new Throttle body (b16a2) that will change the feel..
check the tension on the throttle body springs.. if you can go full throttle and let off slowly.. and it shuts right.. then it's fine..
Throttle pedal is not like a clutch/brake pedal..
85crx509
Sep 3, 2008 11:10 AM
SpeedoKing
Aug 6, 2007 03:09 PM
mr poo
15
Jun 14, 2006 08:09 PM
VtecBrian
Feb 20, 2006 06:01 AM
K i l l a B e e.
Oct 18, 2005 05:42 AM
