Bearing or bushings short shifter
Old May 5, 2006 | 09:04 AM
snouka's Avatar
Default Bearing or bushings short shifter
I notice that the B&m short shifter didn't come with a sealed bearing, you have to take the oem sleeve and change the rubber bushings with those who come in with the shifter.
Skunk2 or dc come with a sealed bearing instead of rubber bushings, I was wondering which is best, I suppose a bearing is.
My stock shifter is loose as hell in gear almost 1 inch both ways. i suspect its the oem rubber bushings that are worn off so that's why I'm a little hesitant of buying b&m shifter
but skunk2 duel bend shifters are back ordered for a couple of months so i'm undecided.
Someone has a suggestion.
Old May 5, 2006 | 09:10 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Bearing or bushings short shifter (snouka)
Both are the same for the most part. But the bearings on my Skunk2 shifter got all f-ed up after a few months. B&M, no problems
Old May 5, 2006 | 09:34 AM
snouka's Avatar
Default Re: Bearing or bushings short shifter (SkoundrelUSA)
What do you mean, the bearings where all fed up? It became loose?
When you say b&m no problems, it's because you have had one ?
Old May 5, 2006 | 09:39 AM
cute little bastard
Yes and yes. I think one of those side bushing things thats suppose to cover the bearings wasn't included in my kit so the linkage crushed the bearings (even though I didn't tighten them that much).
I have a B&M one now and have had no problems. The throw in both felt the same, but I think the Skunk2 is weighted a little bit more so its "firmer"
Old May 5, 2006 | 11:22 AM
snouka's Avatar
For how long have you had your b&m?
Are those four little bushings really better than the oem ones, I guess they are in urethane right?
My main problem is that my shifter is f..ng loose and a do misshifts like once a week because of that. If you tell me that those urethane bushings will last and won't make my shifter go side to side in gears well than that's what I want.
cmross13
Transmission & Drivetrain
Jan 25, 2010 07:05 PM
rutherfordhigh
Oct 27, 2008 10:42 AM
hectic57
Feb 27, 2008 08:16 PM
vlc92189
Sep 14, 2007 06:13 AM
Extreez
Dec 8, 2006 06:08 AM
