Is it my alternator?
Old May 5, 2006 | 08:35 AM
2000GSR2432's Avatar
Default Is it my alternator?
I was driving my car and I noticed my speedometer wasnt working, couple minutes later my lights on my dash were dimming, then my headlights went out one by one, all of my lights check engine/maint req'd/oil/abs/ ect came on, then when i got home my car wont start, jumped it and it started up fine and the lights were on, then when i pulled off the jumper cables it started to do it all again. Does this seem like the alternator or the battery? It wont start unless I jump it.
Old May 5, 2006 | 08:37 AM
Lan's Avatar
Lan
Default Re: Is it my alternator? (2000GSR2432)
Sounds like the alternator to me... You can get it tested at most Auto parts stores.
Old May 5, 2006 | 08:38 AM
Default Re: Is it my alternator? (Lan)
I hope not, they arent cheap...
Old May 5, 2006 | 08:40 AM
Dforce's Avatar
That's what she said!
Same thing happened to me once, thought it was the alternator so I changed it. Turns out it was a alternator fuse So I would check the fuse under the dash first.
Old May 5, 2006 | 08:50 AM
Default Re: Is it my alternator? (Dforce)
is the alternator pretty tough to install?
Old May 5, 2006 | 08:51 AM
Lan's Avatar
Lan
Easy as hell to install
Old May 5, 2006 | 09:02 AM
alright, Ill check the fuse first, prolly take it up to autozone and do the test. Thanks fellaz
Old May 5, 2006 | 09:10 AM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Sounds like your alternator isnt charging your battery and your car is slowly draining your battery down. Although, its kinda strange about the dash lights, the only thing i can think of is the key ignition switch is doing a light test on the dash like before you start your car.... but i would test the alternator and see if it fixes everything otherwise i would do a seperate diagnosis.
Old May 5, 2006 | 09:14 AM
Default Re: Is it my alternator? (ForceFed_Motorsports)
If that is the case, would replacing the alternator fix the problem? Being that the one i have now isnt charging the battery? About a month ago I was getting a compression test done, and they had to jump the battery to even do it, its been fine since, not sure if that has ne thing to do with it, but again ill get a test done.
Old May 5, 2006 | 11:09 AM
CleanLikeJdm's Avatar
Hype-R Stalker
I have a obd2 alternator if that's what you end up needing
Old May 7, 2006 | 07:27 AM
I checked the fuse (sp alternator) and it is blown i keep replacing it but it keeps blowing. I replaced the battery. It starts now but when i started drving the fuse blew again. so i dont know...
Old May 18, 2006 | 05:02 PM
turbod16y8's Avatar
sounds like the o2 sensor is grounding... check that.
Old Jun 16, 2006 | 12:35 AM
buda18's Avatar
Default Re: Is it my alternator? (turbod16y8)
bump
did you figure out what the problem is?
89ED
Apr 28, 2016 06:39 PM
W95civicEXcoupe
Apr 1, 2015 12:29 PM
JwithTHEek
13
Oct 13, 2009 07:05 PM
djrubio
Jul 18, 2009 07:41 PM
92DAIntegraXSI
Nov 28, 2006 04:31 PM
