d15b2 and d16y8 head CR
Old May 4, 2006 | 04:53 PM
mattie_96's Avatar
Default d15b2 and d16y8 head CR
After searching on d-series.org i found a page that stated the compression ratio using everything d15b2(block/pistons..) and a d16y8 head would give about a 10.5:1 CR. I am assuming thats with 1 y8 metal head gasket. I know this is awesome of a ratio for N/A power but it seems like with that much compression tuning of the ecu and fuel pressure is required.
Would using 2 y8 headgaskets bring it down around to 10.1:1 as that seems safer or no?
Old May 4, 2006 | 04:59 PM
vegaskurt's Avatar
Default Re: d15b2 and d16y8 head CR (mattie_96)
Not at all, I have the same setup with a single y8 head gasket. You will have to get an adjustable cam gear to help even things out. I run the cam gear retarted about 1/2 tooth and then the distributer advanced to compensate but still a little retarded.
Initially I had the cam gear advanced and the distributer retarded all the way but it ping'd like crazy.
Old May 4, 2006 | 05:02 PM
mattie_96's Avatar
Ok that seems pretty good then, so you didnt have to do any fuel tuning or ecu tuning at all?
I know thats usually at like 11.5:1 CR but 10.5 is still high so i just wanna be sure..
Old May 4, 2006 | 09:47 PM
vegaskurt's Avatar
Default Re: (mattie_96)
I'm gonna do a compression test in the next week or so to verify cause I plan on doing a low boost setup in the next few months. But yeah, no tuning involved. I am using a stock pm6 right now until I can get it chipped to correct the fuel map when vtec is engaged.
Dueceification
10
Feb 4, 2019 07:03 AM
Dgrep
Jun 25, 2017 05:32 AM
96 EX
Nov 10, 2006 10:35 PM
VitaminB20
Nov 21, 2002 02:45 AM
illmatic_si
Jul 7, 2002 11:11 PM
