DIY Oil Changes?
Old May 4, 2006 | 02:19 PM
asgqwaeg's Avatar
Default DIY Oil Changes?
Is there a DIY for oil changes on here? I searched around this site and couldn't find one.
Old May 4, 2006 | 02:21 PM
ekcivic9's Avatar
not to be a dick or anything... but asking for a DIY on oil change is like asking for a DIY on how to put on your underwear.
pick up a helms... it will help greatly.
Old May 4, 2006 | 02:24 PM
Out of every
Default Re: (ekcivic9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 &raquo;</TD></TR><TR><TD CLASS="quote">not to be a dick or anything... but asking for a DIY on oil change is like asking for a DIY on how to put on your underwear.
pick up a helms... it will help greatly.</TD></TR></TABLE>
LOL
Old May 4, 2006 | 02:25 PM
HXvtec's Avatar
Default Re: (e gee two)
you have got to be kidding me.
ChicagoMike's Avatar
Jack up the car, loosen the oil pan nut, drain the old oil, change the oil filter, put the nut in the oil pan, re-fill the oil. DONE
Ser1N's Avatar
Unscrew the drain bolt from the oil pan, reach up unscrew the filter, put new filter on replace drain bolt refill oil`` done~ DIY!
Old May 4, 2006 | 02:26 PM
ekcivic9's Avatar
here i did a search for you:
http://www.team-integra.net/se...ID=75
same concept.
Luserkid's Avatar
lol.... second person to ask for one of these this week..... same person maybe?
one was asked to me through IM the other this thread. sad.
Old May 4, 2006 | 02:29 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: DIY Oil Changes? (tdn4o8)
-Jack up car.
-Loosen & remove oil-pan drain plug (DO NOT DROP PLUG INTO COLLECTION FUNNEL)
-Let oil drain into container for several minutes (I prefer draining into a funnel & empty 5-gal laundry detergent bottle)
-Stuff several rags or paper towels just below oil-filter
-Loosen & remove oil filter with proper size wrench (rags should absorb oil spilling from filter)
-If no wrench is available, sand the surface of the oil-filter for hand loosening traction
-Remove rags & clean block & oil-filter mounting area with rags (make sure oil-filter gasket is not stuck to the block)
-Lightly lube gasket of new oil-filter with fresh oil
-Install new oil-filter & hand tighten
-Replace drain plug gasket with new one ($.30 from Honda, so buy a bunch)
-Install drain plug & tighten to recommended torque spec
-Fill engine with .5 quarts shy of proper amount of recommended lubricant
-Start engine & let idle for about 30 seconds
-Shut of engine & let sit for 1 minute
-Check oil-level dip-stick & add oil accordingly
-Return used motor oil to special recycling container at local auto-parts store (do not put in garbage)
Old May 4, 2006 | 03:17 PM
asgqwaeg's Avatar
Default Re: DIY Oil Changes? (94eg!)
I just got my first car, so I don't know much about it. Thanks for all the input. Will be changing oil later today
inspector01's Avatar
Nice quick DIY's there......but if you don't know how to do an oil change yet, and don't know anyone that could show you for your first time....take it somewhere and pay them.
Old May 4, 2006 | 03:30 PM
asgqwaeg's Avatar
Default Re: (inspector01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspector01 &raquo;</TD></TR><TR><TD CLASS="quote">Nice quick DIY's there......but if you don't know how to do an oil change yet, and don't know anyone that could show you for your first time....take it somewhere and pay them.</TD></TR></TABLE>
Doesn't sound so hard. I'd rather do it myself so that I can learn.
Old May 4, 2006 | 03:32 PM
SiYouLater's Avatar
Changing oil should be done yourself. It's a good way to start to learn how to do your own wrenching.
SiYouLater's Avatar
Default Re: (ek4o8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4o8 &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't sound so hard. I'd rather do it myself so that I can learn.</TD></TR></TABLE>
Old May 4, 2006 | 03:37 PM
Rev2Eight's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">-Jack up car.
Gotta remember this one. Its better than gutting it with a screw driver
Old May 4, 2006 | 03:39 PM
broketuner-Sol_Si's Avatar
Default Re: (99FBPSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99FBPSi &raquo;</TD></TR><TR><TD CLASS="quote">Changing oil should be done yourself. It's a good way to start to learn how to do your own wrenching. </TD></TR></TABLE>
Plus you can be sure the oil and filter gets changed by doing it yourself. In the news recently a san diego jiffylube got in big trouble for only changing one or the other or in some cases niether.
Old May 4, 2006 | 04:31 PM
Lewy. Dee Ayy's Avatar
Default Re: (broketuner-egb16a)
im teaching my gf's bro how to change his oil this weekend..should i make a DIY?..it will only be like 5 pic's lol...
Old May 4, 2006 | 05:47 PM
E46Kid's Avatar
Default Re: (WhiteOut)
^^ I guess you could for noobs like these who have no idea
Old May 4, 2006 | 05:50 PM
i_kick_turtles's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EkSi &raquo;</TD></TR><TR><TD CLASS="quote">^^ I guess you could for noobs like these who have no idea </TD></TR></TABLE>
Everybody has to start somewhere.
But seriously, have your mom show you or something.
Old May 4, 2006 | 05:52 PM
Default Re: (EkSi)
ya if i remmber il do it..just remmber..we were all noobs at 1 time lol
Old May 4, 2006 | 05:53 PM
beak's Avatar
Old May 4, 2006 | 06:14 PM
Syndacate's Avatar
Default ******* PEOPLE, LEAVE THE KID ALONE!!
*sigh*
ALthough even by my standards this question is low....it's sad how pple just don't help him, just flame him....because obviously if he's asking this question, he doesn't know much about cars...which should be fine, you should be able to help him change his oil none-the-less without being dicks about it...
AddicitiveAllMotor, 99FBPSi, 94eg!, Ser1n, and ekcivic9 -- that's like 5 out of like 20, that's pathetic...
because we all know EVERYBODY else on ht never watched somebody else or had somebody else tell them, they just went up to the car, and did it, when they were 4 years old...
Here, I'll admit it first, I WATCHED MY FRIEND WHO OWNS A GARAGE DO IT BEFORE I DID IT!!!
omg, that makes me so stupid, right?
and everybody on ht is shaking their head "yes" because we all know they NEVER had any help with anything, just born pros of cars, ******* they can take on the guys from honda themselves, they're smarter than honda, smarter than scion, smarter than all the japanese population, why? Because all those brilliant Japanese techs LEARNED how to do it, they weren't BORN with the knowledge like all of the other HT members claim they are...
So when is it guys? When are you going to come out with your BRAND NEW company and BRAND NEW models? I mean if you know more than them, you should out-do them, no?
Some dickless bastard once said (think it was one of those guys on pinks (which I have to hold high respect for even though honda always loses)) that "the honda community is a tight community" -- and I remember reading in the kill stories forum about like, how close the honda community is online, and how no other community's close to honda when it comes to a "Brotherhood" - that people with hondas always got each others back and will help them out etc. etc. etc.
BULLSHIT
******* BULLSHIT
It's like a timestamp requirement, if you're not some rich *** white boy who could spend the pocket change for his brand new GSR motor (that he drives conservatively 100% of the time with, never beats on, never driven hard) and ever bought anything off of ebay then he's **** outta luck..
Long and short of it...
Rolls like this: Honda community is the tightest ever....if u have JDM, a C1, a C5, and/or the most expensive brand name parts..to hit the market
Why can't people just answer his question, and keep flames to urself..I mean even I think this question's uselessly sad...but you don't see me bashing him 6 ways from Sunday, I would have told him how to do it if some other people didn't tell him first -- and it would be pretty useless to ask a mod to do or say something because they're half the bashing in itself...just try and help once in awhile..
Old May 4, 2006 | 06:20 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOut &raquo;</TD></TR><TR><TD CLASS="quote">
ya if i remmber il do it..just remmber..we were all noobs at 1 time lol</TD></TR></TABLE>
No, no, no not honda-tech, they were born with the knowledge, never learned anything from anybody...
Old May 4, 2006 | 06:23 PM
SVOboy's Avatar
You must not be a big fan of aristotle.
OP: Good lucking with the new car, gotta love dat ****.
Old May 4, 2006 | 06:26 PM
Rev2Eight's Avatar
Default Re: DIY Oil Changes? (ej8civic)
Just cause HT doesnt have a write up on the aspects of changing oil doesnt mean the rest of the web is the same. Here: http://www.c-speedracing.com/h...l.php Complete with pictures and everything. Good luck
