honda iat and coolant temp with speed pro?
o.k. my car is running timming is locked in, car idles rock solid at 1200 rpm, I cant get my coolant temp or air temp to read correct, my speed pro unit was setup for gm sensors. Any options, I figured I could just compare my coolant to my autometer gauge and adapt but what about my intake air temp?Any suggestions?want it to be right am going to dyno thursday, Jason
to get the right reading you must use the gm sensors. i found that the honda IAT is about 10 degrees too hot. realistically its no big deal i know a lot of people who run this way. but since your going thru the trouble why not just weld a fitting on to your ic pipe somewhere to fit the gm IAT? and tap the major coolant port to fit the gm sensor?
NovaKnowledgeNow
Jul 26, 2013 11:12 PM
holmesnmanny
Dec 19, 2011 10:40 PM
