where is the p/s rack on a gsr....???
You can swap your power rack with a manual one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arsenal »</TD></TR><TR><TD CLASS="quote">How are you going to steer if you take out the rack?
What are you trying to ask?
Do a search.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR KiNg »</TD></TR><TR><TD CLASS="quote">do u have to do a manual swap??</TD></TR></TABLE>
From what I have read, the answer is no. I recall a "how to" thread on here before. It is not as simple as just disconnecting the lines.
All you have to do is loop the lines, and make sure it has fluid inside the rack.
IF you took the rack out Along with the p/s, you'd have to find an alternate way of steering the car then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">From what I have read, the answer is no. I recall a "how to" thread on here before. It is not as simple as just disconnecting the lines.</TD></TR></TABLE>
That was me. I am running the maunal steering rack in my Integra.
You don't need to leave fluid in the rack. Cut and loop the lines and you're set. Where the rack and pinion gears mesh, is a grease filled chamber that's full of grease whether you have fluid in the piston or not. Leaving the power piston empty doesn't hurt anything.
There never was a manual Integra (94-01) so, there is no true manual conversion like there is in a Civic. The civic and integra racks aren't interchangeable because the mounts are different. The internals are interchangable though if you want faster steering on a civic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan »</TD></TR><TR><TD CLASS="quote">There never was a manual Integra (94-01) so, there is no true manual conversion like there is in a Civic. The civic and integra racks aren't interchangeable because the mounts are different. The internals are interchangable though if you want faster steering on a civic. </TD></TR></TABLE>
Don't state things if you don't know.
The Civic manual rack is a direct bolt into the DC chassis.
If you read the thread I state that I have one in my car at the moment.
That was me. I am running the maunal steering rack in my Integra.</TD></TR></TABLE>
Post the P/N for the Civic rack.
I should have been clearer I guess. The 96-00 Civic racks won't bolt into a 94-01 Integra. It wouldn't surprise me if the older Civics would bolt in. I didn't consider them. They share so many components I guess I should have thought about them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arsenal »</TD></TR><TR><TD CLASS="quote">92-95 Honda Civic CX Steering rack.
Some Del Sol's, just check with your local dealer or go to the Honda e-store. </TD></TR></TABLE>
You just need the rack, correct? The part number is 53040-SR3-A01. It is $377.88 but may be cheaper elsewhere. Here is the link from SL Honda.
http://www.slhondaparts.com/br...=true
You need the steering rack, and the knuckle joint from the Civic, the part which connects the rack to the column.
Here you go, a write up I did
Manual Rack in an Integra How-to:
-------- https://honda-tech.com/zerothread?id=618601 -----------
JDM_SOHC
Oct 10, 2007 07:07 PM
yobtah
12
Nov 11, 2003 01:22 PM
