4x114.3 conversion for a DA
It seems like a lot of people have done the 4x114.3 96 spec ITR coversion, but I can't find any info on it. Does anyone know of a link where I can read up on this swap?
I picked up all of the brakes and wheels for dirt cheap. The fronts have 11" rotors on them, so I'm thinking they may be off of a Prelude. I was just going to put the calipers on, grind them, then re-drill the rotors to 4x100 and bolt everything up, but the local machine shops quoted me $120 to drill 2 rotors. There's no way I'm going to do that. My wheels have a dual bolt pattern, so I was thinking I would just swap the hubs out of the front knuckles and run the 4x114.3 hub. That way I could just buy Prelude rotors and not have to get them drilled every time I put new rotors on. Any idea on what hubs I can use in a DA knuckle? I've heard that Insight hubs might work. Can someone confirm this?
Thanks in advance.
Thanks in advance.
I found this link:
https://honda-tech.com/zerothread?id=1079051
But it's for 5-lug. I'm not sure if the 4x114.3 hub needs the same work done.
Or as another option, has anyone tried Corrado rotors? They're 11" and 4x100.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freakin »</TD></TR><TR><TD CLASS="quote">
Or as another option, has anyone tried Corrado rotors? They're 11" and 4x100.</TD></TR></TABLE>
i would also like to know if those calipers work
