Timing Belt for an OBD0 JDM B16a?!?!?!?!?
Old May 4, 2006 | 09:35 AM
TurboEM1's Avatar
Default Timing Belt for an OBD0 JDM B16a?!?!?!?!?
I need to replace the timing belt/water pump/tensioner on my OBD0 JDM B16a thats in my CRX. What car do I order one it for? Will 99-00 civic si parts work?
Thanks!
Old May 4, 2006 | 09:53 AM
crxnj's Avatar
Default Re: Timing Belt for an OBD0 JDM B16a?!?!?!?!? (TurboEM1)
99-00 civic si (B16a2) or del sol vtec (B16a3) will both work..
Old May 4, 2006 | 04:12 PM
TurboEM1's Avatar
Default Re: Timing Belt for an OBD0 JDM B16a?!?!?!?!? (Mr.speaker)
thanks!
Old May 4, 2006 | 04:55 PM
Jonny Black's Avatar
Old May 4, 2006 | 05:58 PM
Crx Jimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">99-00 civic si (B16a2) or del sol vtec (B16a3) will both work..</TD></TR></TABLE>
actually no ^ , the 99 si has a different part # for the tensioner, just get the del sol stuff it has the same part # as obdo b16
Old May 4, 2006 | 09:22 PM
crxnj's Avatar
Default Re: Timing Belt for an OBD0 JDM B16a?!?!?!?!? (Crx Jimmy)
it all works though,,i dont know why the part # is different..
Old May 4, 2006 | 10:06 PM
rentedcrx's Avatar
i just get the del sol stuff
Old May 5, 2006 | 05:00 AM
TurboEM1's Avatar
Default Re: Timing Belt for an OBD0 JDM B16a?!?!?!?!? (rentedcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
actually no ^ , the 99 si has a different part # for the tensioner, just get the del sol stuff it has the same part # as obdo b16</TD></TR></TABLE>
How do you know what the part number is for the obd0 b16a? Whats the difference between the del sol and civic si parts? Thanks
Old May 5, 2006 | 05:43 AM
wickedEFguy's Avatar
so 93 integra GSR stuff doesn't work then?
Old May 5, 2006 | 06:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 &raquo;</TD></TR><TR><TD CLASS="quote">How do you know what the part number is for the obd0 b16a? Whats the difference between the del sol and civic si parts? Thanks</TD></TR></TABLE>
like I was going to say..but somethign messed up..the 99-00 civic si has one more tooth on it cause the water pump gear is a different size. so it wont worky
Old May 5, 2006 | 06:32 AM
TurboEM1's Avatar
Default Re: Timing Belt for an OBD0 JDM B16a?!?!?!?!? (Jonny Black)
ok so del sol vtec is the correct one?
Old May 5, 2006 | 09:36 AM
rexman's Avatar
Might I suggest thoroughly reading the FAQ at the top of the forum page.
Its your best friend
https://honda-tech.com/zerothread?id=1024595
Old May 5, 2006 | 09:52 AM
crxnj's Avatar
Default Re: Timing Belt for an OBD0 JDM B16a?!?!?!?!? (rexman)
ive used 99-00si,94 gsr,and 92 gsr b17a and they all work,, i dont care about what the part # numbers say..
Old May 5, 2006 | 11:05 AM
TurboEM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rexman &raquo;</TD></TR><TR><TD CLASS="quote">Might I suggest thoroughly reading the FAQ at the top of the forum page.
https://honda-tech.com/zerothread?id=1024595</TD></TR></TABLE>
Thank you. Great post although some conflicting information. Most likely due to the fact that a part from 2 different cars can work on the same engine.
Im going to go with a del sol v tec one since that seems to be what people recomend.
Modified by TurboEM1 at 3:16 PM 5/5/2006
bcorny
10
Oct 28, 2017 08:56 PM
h8ted ek
10
Aug 3, 2007 08:44 AM
GetawayInMoscow
Jun 27, 2005 07:43 AM
EJ8VTEC
Apr 30, 2005 09:54 AM
2.0L EK
Oct 9, 2002 01:56 PM
