o2 sensor on Zc
I'm using a 92-95 exhaust manifold wich i have ported to fit my ZC..
Their is a plug on the manifold (o2 sensor if i'm correct) but i can't figure where it should go........????
Ok i'll explain better...
I have one plug on the exhausat manifolf (3 wires.. green, white and black) but the connector doesd'not fit anywere on my car!? So i just have to cut the connectoter and wire it to the right place.... but i don't know were... the colors doesn't match........ is it more clear?
You will need to unscrew the O2 sensor from the header and plug in your original O2 sensor. 91 and older cars use a one wire O2 sensor while the newer ones use a heated style that have more than one wire.
it should look just like the O2 sensor you have now. Just that it only has one wire running from it.
It will thread into the "bung" that is welded on the header. I will try to find a pic
