what kind of pistons and rods do you suggest?
Old Apr 9, 2002 | 07:38 PM
dontcare61776's Avatar
Default what kind of pistons and rods do you suggest?
About to go turbo on a 94 LS, I have no idea who to go to for pistons and rods and all that. Open to any suggestions. I am looking to boost as much as I can on the track, but it will be a street driven car. So lemme know what you think. Thanks.
Old Apr 9, 2002 | 07:41 PM
FIxALPHA's Avatar
Default Re: what kind of pistons and rods do you suggest? (dontcare61776)
If you go to the search link (upper right hand corner of the screen) and type in Pistons, there will be a couple of info. on it.
I did not try to type in Turbo Pistons, but Im sure something will come up.
Old Apr 9, 2002 | 07:48 PM
Ltech's Avatar
Default Re: what kind of pistons and rods do you suggest? (FIxALPHA)
eagle rods and je pistons
Old Apr 9, 2002 | 08:55 PM
2K_TEG's Avatar
Default Re: what kind of pistons and rods do you suggest? (Ltech)
eagle rods --- endyn/wiesco rollerwave pistons
Old Apr 9, 2002 | 09:00 PM
BoostinDC2's Avatar
Default Re: what kind of pistons and rods do you suggest? (2K_TEG)
Eagle rods with Ross or Arias pistons
Old Apr 9, 2002 | 09:06 PM
immortal's Avatar
Banned
Default Re: what kind of pistons and rods do you suggest? (BoostinDC2)
eagles & je's
eagles & endyns
eagles & arias
eagles & ross
catch the drift?
for the price, the rods cannot be beat.
pistons are.....well, debateable on what you want to do.
i'd go for je's.
Old Apr 10, 2002 | 06:43 AM
newsense's Avatar
New User
Old Apr 10, 2002 | 07:01 AM
X2BOARD's Avatar
Default Re: what kind of pistons and rods do you suggest? (newsense)
JE has a newer 'turbo piston' that has a more dished face, good for boost. The 9.0:1 for the GSR will work fine, not sure if you'll be exactly at 9:1 due to the LS head, but, you'll be close to it !
8.8 JE piston, eagle rod
Old Apr 10, 2002 | 07:31 AM
BROOD's Avatar
Default Re: what kind of pistons and rods do you suggest? (immortal)
eagle rods & endyn pistons (my set-up)
eagle rods & ross pistons (friend's set-up)
eagle rods & arias pistons
eagle rods & je's pistons
The Endyn pistons come with higher compression than the other manufacturers pistons. But it also depends on your application. Just some food for thought?
Old Apr 10, 2002 | 09:43 AM
93LSivic's Avatar
Default Re: what kind of pistons and rods do you suggest? (SLPR)
Some more food for though.. Endyn pistons are just Wiseco pistons--with some sanding done.
Old Apr 10, 2002 | 10:05 AM
Sleeper's Avatar
Default Re: what kind of pistons and rods do you suggest? (93LSivic)
To be honest, Endyn pistons made by wiesco look nothing like wiesco pistons made for hondas. Endyn does sand their pistons, and wiesco does make them, but they are not one in the same.
Old Apr 11, 2002 | 11:58 AM
Trey's Avatar
25 Year Member
Default Re: what kind of pistons and rods do you suggest? (Sleeper)
Weisco makes the pistons to ENDYN specs.....
They'll do it for anyone.
So will Ross and other piston makers.
Old Apr 11, 2002 | 12:31 PM
X2BOARD's Avatar
Default Re: what kind of pistons and rods do you suggest? (Trey)
Just about EVERY piston maker does it too... about $100-$200 more per set of 4.
Old Jun 15, 2002 | 02:59 AM
blufke's Avatar
Default Re: what kind of pistons and rods do you suggest? (X2BOARD)
how much is a set of rollerwaves w/good rings for a stock bore b-series?
Old Jun 15, 2002 | 09:55 AM
Slick GS-R's Avatar
Default Re: what kind of pistons and rods do you suggest? (blufke)
what's wrong with srp pistons?
salvi2dafullezt
Dec 6, 2012 10:18 PM
spoon23_JDizM AkA SpOoN20
Jun 7, 2005 03:07 PM
