headlight voltage
Old May 3, 2006 | 09:00 PM
johnclaunch's Avatar
Default headlight voltage
Is it safe (won't damage wire harnesses or melt housing) to run 65W bulbs (9005) in 55W harness (9006)?
Old May 3, 2006 | 09:27 PM
popeface's Avatar
Default Re: headlight voltage (johnclaunch)
Er, I would say unsafe. That's the reason they're two different model numbers. Otherwise, they'd both be 9006/9005. You're probably likely to melt the wires using a higher wattage bulb, and likely to burn out the bulb using a lower wattage.
Actually... maybe you'd just fry the fuse. Either way, unlikely to be a good idea.
Philly
Old May 3, 2006 | 11:01 PM
soslodelsol's Avatar
Default Re: headlight voltage (popeface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by popeface &raquo;</TD></TR><TR><TD CLASS="quote">Er, I would say unsafe. That's the reason they're two different model numbers. Otherwise, they'd both be 9006/9005. You're probably likely to melt the wires using a higher wattage bulb, and likely to burn out the bulb using a lower wattage.
Philly</TD></TR></TABLE>
i agree with him. your wires, length, and fuses/relays are designed to handle a certain amount of amperage and voltage. engineers designed this for the car already. if you want to go with higher wattage bulbs you can go thru the trouble of redoing your headlight wiring. google the words "AWG chart."
or you could just get better bulbs by better manufactures. eg: PIAA, Hella, etc.
just my opinion. good luck though
jasony0630
12
Apr 11, 2008 09:44 AM
spork motorsports
11
Apr 27, 2007 08:09 AM
Mario.
Jan 31, 2006 08:32 PM
GapxGuy
Feb 20, 2005 10:23 PM
bm3r
Sep 30, 2004 05:57 PM
