somg failure. need advice...
Old May 3, 2006 | 05:00 PM
zaroooo9's Avatar
Default SMOG failure. need advice...
aight, i failed a smog test recently here in cali, my car is registered in massachusetts, but i need the smog test to get a sticker to get on base because im in the marine corps.
now, heres the situation. the header i have is an aftermarket ebay header that i got to replace the stock one thatwas fucked. i didnt even think about having to smog it and the ebay header doesnt have a cat on it, so thats most likely why i failed.
but, i have a 5zigen fireball rear section on my hatch, and the lowest part of the canister where it hangs down has a small hole from scraping.
should i patch up that hole? should i go ahead and buy a whole new cat-back setup (which will be the rsr exmag)? should i buy a brand new exhuast manifold and cat coverter? or should i try and find a used one to pass the smog?
Old May 3, 2006 | 08:05 PM
Ser1N's Avatar
Default Re: SMOG failure. need advice... (zaroooo9)
Well if you dont have a cat on, you need one to pass here in cali =P.
Old May 4, 2006 | 05:59 AM
zaroooo9's Avatar
thank you for pointing out the obvious. you are a genious....
Old May 4, 2006 | 08:10 AM
Ser1N's Avatar
Default Re: (zaroooo9)
Old May 4, 2006 | 08:24 AM
john666's Avatar
lol
im sure someone on h-t will sell you piping with a cat on it. shoot i have 2 laying around i'll rent them to you if your local.. if you know someone that knows someone you dont even have to drive your car to a smog place just pay... then you can get new stuff or stay with what you got.
ware
Dec 23, 2010 08:50 AM
katanamast279
Aug 6, 2009 06:55 AM
I call mine luda
Mar 17, 2007 09:20 AM
tek_civic
Jul 7, 2003 11:46 AM
SimbaDogg
Jul 7, 2003 08:09 AM
