suggestion for quad throttles on my b18c
hey guys i am after some suggestions to make my own quad throttles, what would you suggest.... use my manifold and cut the runners using the standard injector spots and adapt plates to put quads on?
what quads should i use what is good off a motorbike and what can i expect any pictures also would be a help of custom fabbed throttles....
all suggestions will be much appreciated
hayabusas work pretty well, if youre talking about a homemade setup which im assuming, im using them to make a setup for an rsx right now, but there are plenty others that people have used successfully
get honda cbr954 tb's...the tps plugs right in to your stock harness. i think you have to switch two wires around in the connector and that's it. I'm also pretty sure that the fuel line will also fit the itb's fuel rail.
well the suzuki tps isnt a big problem, and what i like about the suzuki tb's is that they come apart so you can space them however you like, i believe the hondas are in pairs if im not mistaken, but you are right about the tps being plug and play
how much do you get bussa throttles for and the other ones reccomended what is the inlet size on the runner and trumpet diameter???? how do the compare to a set of twp i think the company is a set of theres???? havent done this before so trying to get the ideas off the people that have done it be4 by the way i am from australia so i dunno if the US specs are any different??? i got a dc2 vti-r with 99 model type r engine imported from japan
i cant remember the exact size, i believe the inlet is around 48mm, and im not sure of the outlet, bc the set i have is bored out a little
ebay is a good place to look for them
how much did you bore yours out, what revrange are the kind of working at mid low top???? what is a good inlet diameter is the stock crb or bussa ones ok or is bigger better??? how long should the runners be on average
bigger can be better, 50 is better, but ducati is the only one who has 50mm i believe, i could be wrong, as far as the runner length and and rev ranges im not sure yet, i havent done too much trial and error with them yet, there are a few people here that are much more knowledgeable than me on the subject
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by farkew »</TD></TR><TR><TD CLASS="quote">cheers mate much appreciated </TD></TR></TABLE>
no problem, if you have any general questions and cant get a hold of them, just pm me and let me know
you can also try searching in the "all motor" part of honda tech for things like ITB, individual throttle bodies, or similar things. Its been a popular thing to do, and you could probably get some good information by looking at other people's dyno charts and setups. Good luck.
deftones0817
Oct 7, 2002 01:25 AM
